For the Box Guru's
thorshammer
i was pretty damn close..
to answer the question thor.. id say too much vent for that sub on that power..
id throw the other amp on it before i changed the vent again
Well after many many burps lol
This box peaks at 45hz. The bigger port also brought my reactive load through the roof. I'm a couple tenths off of the smaller 8inch pvc (7.75in internal) but with half the power literally. Only clamping 3800 watts, just under 152.
Less power is awesome but with a nominal load of .25, reacive load just over 4ohm, amp turned up as much as it can and still make power, on a 9k board sux balls!!
I'll be throwing in a second amp this week (hopefully) and see what happens.
No doubt! Damn I wonder why that port made so much rise? That does suck balls!!!
I'm sure you all will figure it all out...
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
Port is all external. Box volume is the same. Subs are 100% in control. No unloading at all. In fact they dont move enough. lol
Ray....
With other vent at 3800 watts it peaked at 44/45. At 8k peak is 47/48. I expect with the other amp it will increase peak and score but again it will be limited to a very high reactive load. I'll definately test it first but I'm positive that with close to 16k on the other vent it will be louder than 8k on current one.
By changing port you changed tuning, by changing tuning you change you imp rise curve and change your power output curve the amp is producing. You also change your f3 point by adding port area which can raise your peak by raising your f3.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Vibrating sheetmetal, more port equals lower peak frequency at low power.
If you add more power your peak will go up, which isn't common, normally it drops.
The subs were at maximum excursion with the previous port at a higher power.
Changing impedance curve as AMI has said.
i'm just guessing, i'm not in the same league as Ray,You or AMI. :peepwall:
  • Who's Online   0 Members, 0 Anonymous, 1147 Guests (See full list)
