How To Do The Big 3: Tutorial
Guest MegaloManiac
Guest MegaloManiac
Great Post! But why didnt you solder it instead of crimping?
I dont know...I probally could have but I didnt feel like doing it. My connections are more than solid IMO. cable is loomed, heat shrinked, and electrical taped....what more could I ask for..hehe
lol, megalo do u remember how long those runs were cause i was gunna do the same to my 93 accord, and were did u get the alt and if i may ask how much cause i was lookin for one round 200amp or prolly 150, oh and sense my truck has a 130amp alt i'll prolly go with the 300amp fuses i got in my dist block i baught, oh and doin big three to stock alt should inprove the life on it? or be better to upgrade and how many amps was the stock one u had cause when i had my old system in my honda i had my lights on brite and system all the way up and voltage stayed around 14.4 with car runnin, im thinkin bout takein that alt off n puttin it on the motor im gunna put back in
runs were maybe 4ft iirc. btw my accord is a 6th gen. I have an 200a Iraggi Amputator series.
Big 3 on stock?,will it improve life? idk. but will it help charge better, Yes.
if you upgrade your alternator the Big 3 is a MUST, if you buy an alty from Iraggi or EA they even give you a form letting you know you must upgrade wires.
biggest alts for imports is 200A. I have seen on guy put a 250A GM case alt(i dont remember what brand) on his civic but it required a custom regulator....to risky though
IMO-steps 8-12 (I think it was) need photos.
The most "confusion" I hear/see concerning big 3 upgrades are where/what is meant by "find a spot on the block".
I know it's kinda hard to explain that they (whoever is reading the tutorial) wil have to find a spot on the block that already has a ground wire or a spot for a factory "optional" block ground, and put a bolt there to secure a ground to the block-but that's the most "mistaken" or misinformed thing in my exp and I would def throw some pix of where you grounded on your as an example or just jack a "block ground" pic from one of the other 100 or so Tutorials out there.
Otherwise it looks good.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
easy for you to say. on my first attempt my car went BOOM. i blew a freegin hole through the front fender. im still paying the body shop for that one. i just want as much info on this subject before i do it. like for instance if i cannot fit the extra ring terminal on my alt what do i do? plus i have a side post battery what do i do?
http://www.aaxes.com/pc-21996-364-metra-go...st-adapter.aspx
http://cgi.ebay.com/GM-Battery-Side-Post-A...3QQcmdZViewItem
your choice.
Sounds good.
i'll do so in the morning :)
the best pic i have right now is from a year ago. chasis should be named engine block and not chasis
Posted Image
Technically, both are correct:
The picture is of the connection AT block, but the other end of that cable IS connected to THE CHASIS...hence either name/statement is correct depending on your perspective (kinda a glass half empty/half full question).
But I'm glad you see what I was getting at w/ that pic.
You might also find/take a shot of the before/after of that spot so a person LOOKING for "a ground spot on the block" would know what to look for. The already installed ring/cable somewhat obscures what a person would be looking for before they attatched the cable.
Noob question, but how do you know what size fuse to run? im planning on using a 130 amp alt from the highlander as it is a direct swap for my camry. also would 130 be enough to run about a 1000 watt rms amp?
sorry for so many questions.
Hustle hard, Stack paper,
It's alright, ya'll haters,
It's nothing, We major,
You see me, Hi Hater! =)
~ Manio
WHat size wireing are you using?
Please refer to the other stickies in this part of the forums as you'll find more needed information about wire fusing size...
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
  • Who's Online   1 Member, 0 Anonymous, 1730 Guests (See full list)
