nosho47 Posted January 22, 2012 Report Posted January 22, 2012 I understand... but as of right now i have no battery in the engine bay. they are all in the bed. i'm debating whether to put a d375 under the hood cause it is really tight under the hood. so would that mean i will have to run the wire from the front to the rear then?
sprkn_ranger Posted January 22, 2012 Report Posted January 22, 2012 Im assuming your battery's are grounded to the chassis/frame in the bed? I would just upgrade the engine to chassis/frame until you can get some money to run a 1/0 or 2/0 from the alt bracket all the way back to the rear batts. No need to find room to put a batt up front. Edit-just make sure you find a good solid spot to ground to the chassis/frame and always make sure you ground down to bare metal. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
01VWGREENMACHINE Posted January 22, 2012 Report Posted January 22, 2012 stupid double post on my phone lol I would do the same thing as sprkn_ranger is suggesting http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
sprkn_ranger Posted January 22, 2012 Report Posted January 22, 2012 Sounds like you have an issue with something not shutting off if your not playing and the truck is sitting and draining your batt. my understanding of grounding to the engingblock tk batt was for a better ground from the alt. please correct me if im wrong Yea your right, the alt is grounded through the engine block from the alt bracket (if that makes sense) and that's why you upgrade the ground wire from the block to the chassis. You can also run a wire from the alt bracket to the chassis/frame as well. Here is that diagram if anyone wants it: Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
PURP's 02 Denali Posted February 14, 2012 Report Posted February 14, 2012 so if you have multiple batts would you do it for all batts or how would you wire several batts because i get how to do the BIG 3 and as soon as i start my new build im saving for i will add this but i want at least 2-3 batts and 2 under the hood. i know all the batts are going to connect to the charging batt but would i do BIG 3 on all batts or how would i wire several batts? (asked same thing twice sorry)
MD7786 Posted February 16, 2012 Report Posted February 16, 2012 So if i hhave the stock 80 amp aalt do i need a 200 a fuse?
n8ball2013 Posted February 16, 2012 Report Posted February 16, 2012 you are fusing the wire what is your wire rated at. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
joh17 Posted February 18, 2012 Report Posted February 18, 2012 Informative. I need to do this pretty soon. THanks for the pics.
moh.vze.com Posted February 19, 2012 Report Posted February 19, 2012 My big 3 for the 1999 Camry XLE v6 Top left corner Engine to Ground Top right, Negative on battery to ground Battery positive to Alternator DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Young6er Posted February 23, 2012 Report Posted February 23, 2012 How would i know what amp fuse to get? -Alpine CDA-102 -Rockford Fosgate T1652 -Rockford Fosgate P1652 -Audioque 2200 -Fi Btl N2 12 -KCA Karma 0 Gauge Power -KCA Karma 0 Gauge Ground-Sound deadened trunk and doors
