DODGE-BASSHEAD25 Posted January 31, 2012 Report Posted January 31, 2012 I am about to get two Rockford Fosgate P3 15s. It is a 3.00 cubes max for one so I'm guessing a 6.00 cube max for two. I want a sound that thumps more then actually holding a tone. Something that hits hard rather than holds out tones louder. Would ported or sealed be better. I've heard that ported is better for beats and sealed is better for holding out tones. Is this true??? Any help is appreciated. Car 1999 Dodge Stratus 2.5L V6 Deck Kenwood DDX-512 Head Unit Doors (2) Diamond Audio DA6.6 6.5's (2) Cerwin Vega 3" Horn Tweeters (1) Alpine MRP-F240 for Doors & Tweets Rear Deck(on factory wiring) (2) JVC 6.5's (2) Rockford Fosgate 6x9's Subs firing forward (2) Skar Audio VVX-12's (1) MBQuart ONX1500.1D for Subs Wiring Cadence 4AWG for MBQuart Amp Advance Auto 8 AWG for Alpine Amp Cadence and Monster 4 AWG Wire to Kinetic HC1200 Batteries Stock Replacement up front Kinetic HC1200 in the back for the amps. And yes "I drive a Dodge Stratus" Here is my build log: http://www.stevemead...__fromsearch__1
Miguels Posted January 31, 2012 Report Posted January 31, 2012 i built my first ported box in December and it gets way louder and lower then any sealed boxes i ever had. i do feel like the seal has a longer range though and sounds much cleaner my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Winn Posted January 31, 2012 Report Posted January 31, 2012 Its how you design a box. Experienced people will say Ported boxes all day everyday.. Because they have the smarts to make it sound almost as flat as a sealed enclosure. Although you lose some much with sealed.. I would get a design from a member and build it yourself that would be the best bet You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back. JUST SAY ANTI-AUDIOPIPE
ChevyBoy95 Posted January 31, 2012 Report Posted January 31, 2012 i built my first ported box in December and it gets way louder and lower then any sealed boxes i ever had. i do feel like the seal has a longer range though and sounds much cleaner ported boxes can too, just need to be done correctly. edit: many of the SQ competitors run ported, just needs to be tuned really low iirc. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Joe X Posted January 31, 2012 Report Posted January 31, 2012 If you want quality sound from a ported enclosure use a flared aeroport instead of a slot port, so that and a proper design.
rogue Posted January 31, 2012 Report Posted January 31, 2012 Basically you would rather be louder than sound perfect. Ported is the simple answer to your question and 2nd the others on here about getting someone to design it for you. Start a new thread asking for help and list your max dimensions you can use in your car and im sure you will be well on your way in no time. BMW X5 Stealth Build w/ IPAD BMW 325i Rear Deck Digital Designs Build BMW 325i Car PC Touchscreen Bezel Build
mlstrass Posted January 31, 2012 Report Posted January 31, 2012 something other then RF subs would have more thump aero will sound NO different then a slot port assuming you have enough port area and don't get port noise...
