DD 3515 C motors?
SlamminBeats
where can you find dd subs and info on the website it doesnt show the c ones and you cant order there
To order them you have to call a dealer
C motors are an out dated version of the motor the 3500s can run, and DD says they have some in B-stock they are willing to build.
crown vic has a solid rear seat. sub up port up..... yeah..... and 32 is too low for them. he probably didnt have enough port. DDs love port. i wonder what load he was giving his amp too.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
so if a cars seat is solid or if theres like a gas tank in the way is it better for sub up and port up and what about tuning
its just bad all around. And for tuning, on DDs, not 30 hz, more like 36-38 maybe?
no its never good in a trunk its all about trying to make it fit. thats the only reason to do it like that in a trunk car. you really have three options
fire forward and seal off. cant do that in a crown vic
fire everything to the rear
port through the rear deck. With the way the trunk of a vis is I dont thin kthats a viable option either.
Tuning for DD's are different. AQ as well. Youll notice most of the DD and AQ guys tune higher. Ami customs is tuned to the mid to high 30s. So am I. I think mlstrass is as well. bottom line is they are strong enough to play low very well below tuning without unloading.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
mhmm 9515
mhmmmm port
get the 18
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 2479 Guests (See full list)
