The choking noise you hear is port noise, which is what you'll get if your port is too narrow in relation to the height as well.
I can still change the port on my box im making right now, but idk who can do it for me haha to make it nice, i have the whole box pretty much made, but dont have port made in their yet so if anyone can change it for me id be a pretty happy camper
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
haha if you supercharge your motor you will notice more punch. the box tuning really wont affect your punch that much i wouldnt think. the motor is the motor and unless you get more mottor or more cone area the punch will be same. best bet is SC if possible then adding more motor strength
true true, my buddy with a 9512 changes his box to around 37 hz, n was able to turn high pass up more making it punch pretty nice. Right now with my tuning my DD doesnt like to have high pass turned up anymore than it is right now, so theirs not much punch.. but hey gotta love the lowwssss
im tuned to 37 hz with my 2 2510s and they hit me in the chest real nice
how many cubes is your box? shit i wanna try a smaller box and put tuning around 37 hz just for a fun project when im bored now and see what difference it makes
i have a seperate box for each woofer. double baffle front. and they each get 1.5 on the dot net. but im gunna build a new shared chamber box giving them 1.7 each. the SC allows for a bigger box due to more control of the woofer. bigger box= hopefully bigger sound while still retaining punch
How does the current box im building sound to you?
Outer dim.
16" high
28" wide
30" deep
Port
2.5" high
26.5" wide
26" long
Net vol. 4.13 ft.^3
tuning freq. 36.33hz
Port area per ft. 16.03 in sq ?
honestly id go 4.5 net and 37 hz tuning just because ive had best results with that for me. and 17 -18 inches per cube. maybe 70 sq of port no more though.
Edited by Bump4life
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
yeh ik, Can someone change my port specs on the box to make it correct and no port noise. The outer dimensions wil have to remain the same tho
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
mount sub on top. double baffle. so 13.15 high by 5 inches wide should do the trick. and make sure you get 4.5 net after braqcing and sub displacement. 17-18 per cube
edit: port back
what kinda car was this going in again?
Edited by Bump4life
BMW M340 xDrive
Tuned too low is probably causing the sub to roll off on the top end too quickly.
I like DD/AQ's for the punch they have as it's perfect for the music I mostly listen to.
4.25-4.5cubes net, 16^2 port area tuned 35-38Hz should be plenty punchy. Also LPF 80-100Hz...
x2 on your port, way over the 9:1 ratio...
kk, right now when i turn my lpf up any over 70ish it likes to make a popping noise when it punches =/ hopefuly this new box solves the problem
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
tune higher. 4-4.5 cubes no lower than 35 tuning and about 17-18 inches per.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thanks n8
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
  • Who's Online   0 Members, 0 Anonymous, 2073 Guests (See full list)
