Joe X Posted February 3, 2012 Report Share Posted February 3, 2012 (edited) They used to list them, found them in two different loactions around the internet: XL 12" Mounting Depth 7" Mounting Hole Diameter 11" Motor Width 8.75" Weight 54lbs VC Diameter 3" Flat 8 layer Displacement .19³ ft Magnet Weight 50lbs Power Handling RMS/Peak 1500/3000 Impedance (Ohm) d.7, d1, d1.4, d2 Sd 494.00 cm² Fs 38.90Hz Qms 6.51 Qes .31 Qts .29 Xmax 26mm Sensitivity 90.73 Suggested Sealed N/A Suggested Ported 1.5³ ft Vas can be "calculated" by formulas and it gave me: 1.456 cu.ft If not here's how measure Vas (and the other parameters): http://sound.westhost.com/tsp.htm Edited February 3, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
matt402 Posted February 3, 2012 Report Share Posted February 3, 2012 I got a woofer tester from PE. Its pretty easy to use and inexpensive. Only 80-90 bucks IIRC. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=390-804&FTR=dayton%20woofer%20tester Quote Link to comment Share on other sites More sharing options...
OBI Posted February 3, 2012 Author Report Share Posted February 3, 2012 (edited) Found the T/S Specs for my subs. 15" Mounting Depth 8.25" Mounting Hole Diameter 14" Motor Width 8.75" Weight 54lbs VC Diameter 3" Flat 8 layer Displacement .23³ ft Magnet Weight 50lbs Power Handling RMS/Peak 1500/3000 Impedance (Ohm) d.7, d1, d1.4, d2 Sd 791.00 cm² Fs 35.60Hz Qms 6.98 Qes .32 Qts .30 Xmax 26mm Sensitivity 93.70 Suggested Sealed N/A Suggested Ported 3.5³ ft Edited February 3, 2012 by OBI Quote Link to comment Share on other sites More sharing options...
Joe X Posted February 3, 2012 Report Share Posted February 3, 2012 Found the T/S Specs for my subs. 15" Mounting Depth 8.25" Mounting Hole Diameter 14" Motor Width 8.75" Weight 54lbs VC Diameter 3" Flat 8 layer Displacement .23³ ft Magnet Weight 50lbs Power Handling RMS/Peak 1500/3000 Impedance (Ohm) d.7, d1, d1.4, d2 Sd 791.00 cm² Fs 35.60Hz Qms 6.98 Qes .32 Qts .30 Xmax 26mm Sensitivity 93.70 Suggested Sealed N/A Suggested Ported 3.5³ ft And in case you didn't read up there you are missing Vas. Calculated Vas for you but the best way is measure it, and the device suggested can't do it. Quote Link to comment Share on other sites More sharing options...
OBI Posted February 3, 2012 Author Report Share Posted February 3, 2012 And in case you didn't read up there you are missing Vas. Calculated Vas for you but the best way is measure it, and the device suggested can't do it. Did you use suggest box specs giving by dc for Vas? Quote Link to comment Share on other sites More sharing options...
Joe X Posted February 3, 2012 Report Share Posted February 3, 2012 (edited) Vas belongs to the subwoofer, you use Vas for designing the box, I calculated it from the other parameters but better measure it. Also left you a link with 2 independent methods to measure Vas. Edited February 3, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
RooTxBeeR Posted February 3, 2012 Report Share Posted February 3, 2012 Be careful, DC has all new lines out as M2 versions, all the older ones are M1, so make sure you find the right one to match the sub that you have. GL! Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
