ChevyBoy95 Posted February 4, 2012 Report Posted February 4, 2012 going to run about 5k rms on music, no burps. 200amp mechman 3 hc1400s and a hc800 please only answer if you have ran 5k or over. just want to make sure my electrical is up to the job when i recone my level 5. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted February 4, 2012 Author Report Posted February 4, 2012 ttt Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted February 4, 2012 Author Report Posted February 4, 2012 375 would be burps. I'm only MUSIC Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
SnowDrifter Posted February 4, 2012 Report Posted February 4, 2012 (edited) Music is generally accepted as a 50% duty cycle (bass notes don't last forever, as well as box rise among other things) 5000 RMS amp - 90% effeciency at 14.4v - 386a of current draw. 50% duty cycle - 193a. Factor that in with the rest of the electrical demands of the vehicle (seems between 40-50a on average) and you have ~250a average of current draw that you need to feed as a MINIMUM. Even then, there will be times when it will peak well above this - your main issue here will be voltage drop. So pretty much what Gregg said - more batteries, I would say bigger alternator too so your voltage doesn't get too bad (don't want to fry a nice amp now do we?). Cheers Edited February 4, 2012 by SnowDrifter Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
14dbass Posted February 4, 2012 Report Posted February 4, 2012 It is going to depend on if your alt can make up the difference, you do not have enough battery IMHO. I have never had mechman so I don't know what that will do at idle. Quote Suburban Build Log "So much money and time spent making copper winding move up and down a magnetic pole" DC Audio Eclipse
ChevyBoy95 Posted February 4, 2012 Author Report Posted February 4, 2012 (edited) ok so more batteries/ bigger ones. ill hopefully end up with 4 or 5 hc1400s, or 3 hc1400s and a hc2000. this is just a daily beater. right now running about 3k i have .1v of drop full tilt, and .3v at idle and cant get anything hot at all. a little drop is ok, just want to maintain 13.5v or higher. my alt is 125 at idle (800rpm) 200 at 1200. it does actually about 210 at 1200 and 130ish at idle. Edited February 4, 2012 by ChevyBoy95 Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Dangrebel Posted February 4, 2012 Report Posted February 4, 2012 Throw another alt in to help out if you can afford. Quote 1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
ChevyBoy95 Posted February 4, 2012 Author Report Posted February 4, 2012 Throw another alt in to help out if you can afford. well, instead of batteries, i might switch it out for a singer 270a or high amperage alt. no duals though. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
