Blow Through Advice.
Nine8SST
something ive seen people do in cut-threws on mdf is to completely resin the outside of the box..done this on a blow thru we did recently seems to be working well..been 3 months iirc no issues
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
put a topper on it if you can even if its just a soft tonneau cover.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I have been watching craigslist for one, the pop up pretty often for around 100-200 bucks for a fiberglass one. I have been wanting one even before I decided on the blow through, so that's definitely in the plans in the next few months.
Nate, is your truck a blow through, or walled?
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
Polyester or epoxy?
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
just used fiber glass resin seems to help it from drawing moister..but like n8 said earlier if you get a good cover shouldnt be much of an issue
power: dd m4
The more I think about it the more I want to hack a hole in my Ranger. I'm tuned in for info here.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
walled everything in the cab. nothing in th ebed.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Damn that's alot of equipment in the cab. Mind posting some pics? Not to thread jack, just curious on your layout. I have a friend with a Silverado wanting a wall and we were planning doing batteries and possible amps in the bed.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
Nice man!!
No problem LOL...you know I don't give a shit.
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
Sani....I just looked at the build in your sig....and your box is pretty much what I'm picturing in my mind. What I have to work with is 48" wide x 16" tall x pretty much and length it needs....so, plenty of room. I'm assuming Birch is the way to go? Seems like even if I seal the shit out of it MDF may pose an issue with moisture......especially in Washington?
My 4 18 box was mdf and i lost it to water damage.. not much water will get into your bed if you do it right. Tonneau top and accordian boot do a lot of good. But the moisture that does happen to get in there will soak into MDF like a wick.
  • Who's Online   1 Member, 0 Anonymous, 1545 Guests (See full list)
