The Black Nasty - 6 HDC4 15s + 6 Q1-3500D.1s = 162s on music!!!
Thanks for the advice bro. Do you have any pics of you grounding the bracket to the frame?
No, I sure don't and it is really hard to see with everything in there now, but all I did was weld a 5/16 bolt to the back bracket plate and then weld another 5/16 bolt to the top of frame on the A-Arm bracket which is nice and flat. Then installed 4 1/0 wires between those to points about 8 inches each, also ran a 1/0 ground the battery negative from the frame bolt as well.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
you have fuck load of wire lol!
Around 700 ft of 1/0 total, 14 full 50 ft spools worth all Stinger.
Evo X build log
looking good !
one question thou , wont you damage the alts by having them 'off' while their spinning/truck running ?
No they are just acting like an idle pulley when off, mechman said they will be fine.
but wouldnt they have a different spin resistance (be harder to spin) than a regular idler pulley?
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
looking good !
Of course but not nearly as much as when they are charging and outputting current if they are only putting out 10 amps why have them on? It is a really nice feature to have, there were times with my old alts that when I was backing up all four running would pull the idle down so much that it would stall the truck. That doesn't happen with just two charging/spinning plus my idle is higher now too so.....
Evo X build log
sounds good man but from the way im understaning it id rather have control over each one individually instead of 2 at a time you know? and to your question to the other dude isnt it better to use the frame when you have that many amps? anyways your under hood looks damn sexy bro cant wait til its done hopefully by then ill have a job and be able to come get a demo :D
You would need 4 regulators if one did that and for me there wasn't enough room to put 4 of those under my hood. And your other question copper is a far better conductor then steel, in ANY high current install I run dedicated grounds. And any alternator manufacturer or battery company will tell you the exact same thing, hmmm I wonder why? Because it works. And you bet I will be givin out demos like crazy when it is all finished.
Evo X build log
yeah i knew copper was a great conductor but didnt know how good a conductor steel is i do know that the best condutor ive heard of is gold but that gets pretty damn expensive
  • Who's Online   0 Members, 0 Anonymous, 2357 Guests (See full list)
