zigzag420 Posted February 12, 2012 Report Posted February 12, 2012 what kind of power could i expect from my dc 2.0k at .5 ohms?, also was thinking about uprading to the new xl 18, what would be a good amp for the xl? Quote 2003 Jeep Grand Cherokee LTD. pioneer 80prs B2 ES6.1I....................................Other Sub Stage: B2 Zero1, B2 Quattro.......................B2 Quota Tantric HDD 12's..............................B2 AS 12" 6^3 33 hz......................................4th Order BP 40hz
woodzyspl Posted February 12, 2012 Report Posted February 12, 2012 ima say 2k due to box rise/voltage drop Quote AUSTRALIA do i need say more? HU: some crap pionee AMP: dc 9k @ 18v SUB: 4 elevation audio sqx 12" Battery: 2 neuton power 8200d burp setup for fun 152's soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
CJ18 Posted February 12, 2012 Report Posted February 12, 2012 at .5 ohm reactive, you can probably expect it to kick into protect and stay there. It will do 2000w at 1 ohm reactive and 12.6v. Quote
zigzag420 Posted February 12, 2012 Author Report Posted February 12, 2012 at .5 ohm reactive, you can probably expect it to kick into protect and stay there. It will do 2000w at 1 ohm reactive and 12.6v. what do u mean reactive? iv been told by many people even a rep from dc that they are .5 stable Quote 2003 Jeep Grand Cherokee LTD. pioneer 80prs B2 ES6.1I....................................Other Sub Stage: B2 Zero1, B2 Quattro.......................B2 Quota Tantric HDD 12's..............................B2 AS 12" 6^3 33 hz......................................4th Order BP 40hz
CJ18 Posted February 12, 2012 Report Posted February 12, 2012 Nominal= what you wire your subs to before you put a signal to them--ex: 1 Dual 1 ohm sub wired down to .5 ohm. Reactive= actual ohm load seen at the amp while a signal is being put to the subs. This will change based on the frequency being played. The only way to find out what it is, is to clamp the amp. Can you wire to .5 ohm Nominal? Yes. Is the 2k .5 ohm stable, No. Amps that are .5 ohm stable, can be played with a reactive ohm load of .5 ohm. Quote
TeamHT Posted February 12, 2012 Report Posted February 12, 2012 Why wire down though? I never understand this logic. If you need 2,500 watts, get a 2,500 watt amp. Want 4,000? Get a 4,000. Although an audible difference from 2,000 watts to 2,500 may not even be there. Quote Tell me...does this smell like chloroform to you?
zigzag420 Posted February 12, 2012 Author Report Posted February 12, 2012 (edited) Nominal= what you wire your subs to before you put a signal to them--ex: 1 Dual 1 ohm sub wired down to .5 ohm. Reactive= actual ohm load seen at the amp while a signal is being put to the subs. This will change based on the frequency being played. The only way to find out what it is, is to clamp the amp. Can you wire to .5 ohm Nominal? Yes. Is the 2k .5 ohm stable, No. Amps that are .5 ohm stable, can be played with a reactive ohm load of .5 ohm. well i have been told otherwize like i said, they are .5 ohm stable. im going to wire the sub to .5 ohms. Edited February 12, 2012 by zigzag420 Quote 2003 Jeep Grand Cherokee LTD. pioneer 80prs B2 ES6.1I....................................Other Sub Stage: B2 Zero1, B2 Quattro.......................B2 Quota Tantric HDD 12's..............................B2 AS 12" 6^3 33 hz......................................4th Order BP 40hz
zigzag420 Posted February 12, 2012 Author Report Posted February 12, 2012 Why wire down though? I never understand this logic. If you need 2,500 watts, get a 2,500 watt amp. Want 4,000? Get a 4,000. Although an audible difference from 2,000 watts to 2,500 may not even be there. cuz why spend more money if you can just wire down! i already have the 2k and wouldnt mind upgrading to a different sub. Quote 2003 Jeep Grand Cherokee LTD. pioneer 80prs B2 ES6.1I....................................Other Sub Stage: B2 Zero1, B2 Quattro.......................B2 Quota Tantric HDD 12's..............................B2 AS 12" 6^3 33 hz......................................4th Order BP 40hz
kryptonite Posted February 12, 2012 Report Posted February 12, 2012 It is my understanding that if u wire an amp below its printed stable load rating, extra stress is put on the amp, your electrical and subs. Not only voiding any warranty but you thinkibg you should have listened to cj. He knows his stuff and if u don't wanna listen, be my guest, but if u blow it at .5 and expect rusty to warranty it because a rep said it wae stable, I have property on mars ill sell you dirty cheap. Quote DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
CJ18 Posted February 12, 2012 Report Posted February 12, 2012 Nominal= what you wire your subs to before you put a signal to them--ex: 1 Dual 1 ohm sub wired down to .5 ohm. Reactive= actual ohm load seen at the amp while a signal is being put to the subs. This will change based on the frequency being played. The only way to find out what it is, is to clamp the amp. Can you wire to .5 ohm Nominal? Yes. Is the 2k .5 ohm stable, No. Amps that are .5 ohm stable, can be played with a reactive ohm load of .5 ohm. well i have been told otherwize like i said, they are .5 ohm stable. im going to wire the sub to .5 ohms. Listen to who you want, I am telling you that the amp is NOT .5 ohm stable and running it at .5 ohm will VOID your warranty. If you have to ask the question, then I highly recommend that you DO NOT do it. If you doubt what I am saying, I am a DC Rep and know these products very well. I have the experience and knowledge to do what you are wanting to do, but that does not mean that I can recommend that anyone else do the same. When I wire my amps lower than recommended, I am doing so at my own risk. Quote
