Amps won't turn on. 16 volt system. relay for turn on
irpirate
Hello all, having a bit of a puzzler. i have 4 sundown 3500s hooked up to my 9 16 volt xp1000s. power grounds are wired up. remotes are all jumped together.
i tried using the normal turn on and nothing.
i jumped the bat + to turn on and everything turns on.
hooked up a bosch style 5 pin relay
30 to 16 volt bats +
85 to ground
86 to 12 volt turn on/remote wire.
87 to amp turn on
87a nothing hooked up
thanks guys!!!
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
Relays are good to 24v so its gotta be a wiring issue
Okay are you running 12 volt and 16 volt? What voltage is your head unit running at? And just from looking at it you have the relay hooked up backwards.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
That is from 12 volt.com
86 goes to remote turn from HU or ignition
87 12 volt constant
30 remote turn for each amp, just daisy them like you said
85 ground
87a is nothing connected
Evo X build log
Relay seems fine. My concern would be that the amps can't handle 16v on the remote input
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I guess you could wire the sides of the coil in the relay either way and it will work. So it must be a wiring issue then go back over your wiring.
Evo X build log
Keep in mind that some relays have a diode inline with the coil to help keep it from ringing....and that may be his problem. OP, Try swapping your inputs on pins 85 and 86.
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
I thought of that too, allows the coil field to collapse without a voltage spike. Which if that was the case he wouldn't get anything out of them if wired backwards, just have to check to see if there is a diode present to attach his remote turn lead from HU to positive side of coil, which would be the cathode side of the diode, side with stripe on it.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 1157 Guests (See full list)
