So say its the exact same sub
2 12s vs 1 18
the 18 has more cone area, but not by much.
The subs will be top of the line.
Which do you prefer?
800 oz of magnet with 2 12s?
or 1 18 with 400 oz of magnet but a little more cone area?
I have always wondered this too..
SOLD
2006 Ford Ranger Single Cab
2 DC XL 15's
2 Crescendo BC2k's
4th Order Blowthrough
CURRENT
2012 Dodge Charger R/T
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
many variables but heres food for thought, its not about the area of a circle, its about comparing the SD or piston area
case in point, FI Q 12s vs FI Q 18
2 12s SD=2(481)=962cm^2
1 18 SD= 1210cm^2
thats a difference of 38.44sq^2 in favor of the 1 18" using the piston area
2 12s AREA=226.08sq^2
1 18 AREA=254.34sq^2
thats a difference of 28.26sq^2 in favor of the 1 18" using area of a circle
in other words, SD is the accurate way to compare speakers because of the surrounds used, the area of a circle is a vague general way to compare
(i'd likely pick 2 12s because of the smaller box size and higher power handling since you have twice the voicecoil)
Edited by Decaf
Motor force vs Cone area, shitload of variables, but 1 thing that matters alot is power.
fully powered 18 cone area > motor force half power 12s.
also ideal box etc..... so whats the power and subs !?
DD 9500s
2k to start, eventually 4k
If you are going to add more power, i would take double the sub, than running the same single sub.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
magnet weight doesnt equate to a linear motor strength increase as you are suggesting.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1623 Guests (See full list)
