SlamminBeats Posted February 13, 2012 Report Share Posted February 13, 2012 So say its the exact same sub 2 12s vs 1 18 the 18 has more cone area, but not by much. The subs will be top of the line. Which do you prefer? 800 oz of magnet with 2 12s? or 1 18 with 400 oz of magnet but a little more cone area? Quote Link to comment Share on other sites More sharing options...
slaughter Posted February 13, 2012 Report Share Posted February 13, 2012 I have always wondered this too.. Quote SOLD 2006 Ford Ranger Single Cab2 DC XL 15's2 Crescendo BC2k's4th Order Blowthrough CURRENT 2012 Dodge Charger R/T 2 Tantric HD 12's Ampere 3800 2 XS XP 3000's Link to comment Share on other sites More sharing options...
SlamminBeats Posted February 13, 2012 Author Report Share Posted February 13, 2012 if like cone area is off by 20, i would think the 2 12s would do more damage? Who knows though? Quote Link to comment Share on other sites More sharing options...
__d_a_v_i_d__ Posted February 13, 2012 Report Share Posted February 13, 2012 Motor force vs Cone area, shitload of variables, but 1 thing that matters alot is power. fully powered 18 cone area > motor force half power 12s. also ideal box etc..... so whats the power and subs !? Quote Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!! Link to comment Share on other sites More sharing options...
Decaf Posted February 13, 2012 Report Share Posted February 13, 2012 (edited) many variables but heres food for thought, its not about the area of a circle, its about comparing the SD or piston area case in point, FI Q 12s vs FI Q 18 2 12s SD=2(481)=962cm^2 1 18 SD= 1210cm^2 thats a difference of 38.44sq^2 in favor of the 1 18" using the piston area 2 12s AREA=226.08sq^2 1 18 AREA=254.34sq^2 thats a difference of 28.26sq^2 in favor of the 1 18" using area of a circle in other words, SD is the accurate way to compare speakers because of the surrounds used, the area of a circle is a vague general way to compare (i'd likely pick 2 12s because of the smaller box size and higher power handling since you have twice the voicecoil) Edited February 13, 2012 by Decaf Quote Link to comment Share on other sites More sharing options...
Joe X Posted February 13, 2012 Report Share Posted February 13, 2012 What about Vd Vd = Sd x Xmax Quote Link to comment Share on other sites More sharing options...
SlamminBeats Posted February 13, 2012 Author Report Share Posted February 13, 2012 Motor force vs Cone area, shitload of variables, but 1 thing that matters alot is power. fully powered 18 cone area > motor force half power 12s. also ideal box etc..... so whats the power and subs !? DD 9500s 2k to start, eventually 4k Quote Link to comment Share on other sites More sharing options...
Socky Posted February 13, 2012 Report Share Posted February 13, 2012 If you are going to add more power, i would take double the sub, than running the same single sub. Quote Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz Link to comment Share on other sites More sharing options...
SlamminBeats Posted February 13, 2012 Author Report Share Posted February 13, 2012 If you are going to add more power, i would take double the sub, than running the same single sub. yea im leaning towards the 12s in this case Quote Link to comment Share on other sites More sharing options...
STEvil Posted February 14, 2012 Report Share Posted February 14, 2012 magnet weight doesnt equate to a linear motor strength increase as you are suggesting. Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
