baaudio Posted February 17, 2012 Report Posted February 17, 2012 Okay so my girlfriend's explorer, stock electrical 2000 explorer with a 130 amp alt only charges at 13.8. I had the alternator tested and its fine, I tried another battery as well with no difference. I've done the big 3 with 1/0 and left all stock wiring as well. Even with a different alt it charges low. Any reason for this? 13.8 just seems awfully low to me especially with everything in proper order. Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
SoCaLBaMF Posted February 17, 2012 Report Posted February 17, 2012 If its hot then thats pretty normal, or its just regulated. 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
baaudio Posted February 17, 2012 Author Report Posted February 17, 2012 I believe its just regulated at 13.8. But what I'm wondering is why regulate it so low? I have a 97 explorer and I charge at 14.8 with a stock alt. Granted i have the 4.0l ohv engine and hers is the 4.0 sohc motor. Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Baydestrian Posted February 17, 2012 Report Posted February 17, 2012 My alt for my 99 Caddy Seville is stock 140amp and it charges at 13.8-14.1, depends on the weather and stuff. It is rebuilt I believe since it went back back in 2009, with that one I would hit the gas and it would go up to 14.4 this one basically just stays around 13.8+. I believe lower than 13.5 is when you should be concerned? 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
OrionStang Posted February 17, 2012 Report Posted February 17, 2012 PCM limited. My stang is the same way unless my batts get way low. SMD Super Seller My Feedback Thread
baaudio Posted February 17, 2012 Author Report Posted February 17, 2012 Good to know. Thanks guys. So would it help the Kinetik hc800 I have in there to put it on a charger once n a while? Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
