So I just put in my 2nd yellow top in my trunk and the volts are staying at 11.3 and when bumping drops to 9.5. I haven't done the big 3 yet but will within a week. Will that help? Or is the only thing I can do is get a h.o. alt.? I have the back bat running 0 gauge to my cap then 4 out of cap to amp.
Get rid of that cap for one..doing nothing but added stress to your charging system, and isn't helping with your voltage issue. What kind of car is this in? What is the factory alternator's amp rating? My guess is that your alternator can't keep up with the added battery and you're depleting the reserve on the batteries and then your voltage is dropping off a cliff. Might be time to invest in a H/O alternator. I did, and haven't been happier.
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
How did you wire in the second battery?
Is it new?
Did you check voltage before installing?
Did you charge it before installing?
Is this with the engine running?
What is the voltage at the front battery?
Need info to help.
SMD Super Seller
My Feedback Thread
No I didn't charge the back b 4 install cause i was told i didn't need tto on a yellow top. Could I just get a charger and throw it on for a lil bit? Its a 2001 Camry and factory alt is 80 amp.
Edited by MD7786
