4ch Wiring help.. Impedence questionss
h23a3lude
So I've just recently bought a new DB Drive Okur A4 4200 amp. I have a set of DB Drives' platinum 6.5's which are 3ohm impedence. I intend to buy another set of 6.5's or 5.25's but they will more than likely be 4ohm impedence, is it okay to run two different impedences as long as they are on seperate channels? And i cant run the same speakers in the rear because my trunk springs wont clear a bulky magnet :bull: but I dont wanna fry my amp, and im just not entirely sure so i figured i'd check before i wire it all. Thanks!
92 Honda Prelude SI H23a3
HU: Alpine CDA-105
Front Stage: DB Drive PT6.0 6.5"
Rear Stage: Junk pioneers (Not sure what im wanting to do in the trunk, waiting)
Speaker Amp: DB Drive A4 4200
Sub Amp: MB Quart DSC1500.1
Subs: 2 12" MB Quart Premiums
Box: Slot port tuned to ~34hz
Wiring: Kicker Ultraflex 0awg and Big 3
Alt: Stock (saving for a 200amp Excessive Amperage)
Batteries: Optima Yellow Top and Stinger SPV44
Extra Equipment:
Two Rockford Fosgate T2 12's (Recones in future)
Kicker ZX1000.1
Selling:
4 channel amps normally should see 4 ohms per channel ... some, maybe 2 ohms if channels 1 and 2 or 3 and 4 are bridgeable ...
Not sure if 3 ohms per channel will work on that amp ... might want to ask DB Drive on that one ...
I'm talking normal conditions here ...
Alright. I'll ask them just to make sure
HU: Alpine CDA-105
Extra Equipment:
Kicker ZX1000.1
Selling:
3 is fine. if it can do 4 and 2, it can do 3.
make sure you run both front channels at the same impedance and both rear channels at the same impedance however. Front channels at 4 and rear at 3 is fine.
the front and rear do not have to be the same.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Thank you MrSkippy! That answers my question.
HU: Alpine CDA-105
Extra Equipment:
Kicker ZX1000.1
Selling:
Keep in mind the lower ohm load will increase the power output of the amp (for those channels).
If it does 200w @ 4 ohm and 400w @ 2 ohm I would estimate 300w @ 3ohm per channel. I'm not too fami.iar with DB Drive amps and if their amps are rated Peak or RMS, just keep this in mind so you dont over power your speakers and blow them.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Yeah i understand all that just didnt know if i could do different ohm loads at the same time. Thank you all!
HU: Alpine CDA-105
Extra Equipment:
Kicker ZX1000.1
Selling:
  • Who's Online   0 Members, 0 Anonymous, 1064 Guests (See full list)
