Team Sundown Russia tests Skar Audio VVX-12's
So we've naturally been keeping an eye on Skar Audio over the past year or so due to the questions we get here in Russia from the people that follow our builds....you know, the usual - what do yoy think about Skar subs? when do you think they will be available in Russia? how do they stack up against so and so sub?
so we had to get some :eek5wavey:
As most of you already know - the quality and overall fit and finish on these subs is amazing. everything from the full-size dustcap to the magnet boot is just the way it should be
So we popped the into the shop's Audi A4 sedan
box is just a shade over 4.5 cubes net with a single 8" flared port firing to the side...on paper tunning is 37hz, but it peaks much lower due to the loading effect of the port firing into the fenderwell
amp is a Sundown Audio SAZ3500D @ 0.5ohms with two XS Power bats and Shok industries wire....the stock alt in the audi is a dog however, so voltage easily drops below 12
so, on to the scores
with the subs fresh out of the package, with no break in we managed a 147.4 @ 30hz
this was apparently no sweat for the subs and the were laughing at the power.... which was clamped at 2791 watts on this run with a drop to 11.6 volts and rise to just over 1.1ohms.... very impressive
then we tried 30hz and were rewarded with a 148.00 !!!
the subs obviously need more break in - we clamped 2640watts this time with 12volts and slightly over 1.2ohms
then it was time to let them wang full-tilt ob a pretty rough track
full-tilt for 3 minutes on a saz3500@half-ohm metering 146+ the whole time with no hint of coil-smell = win in my book
overall - we are really impressed with the subs...they pound the lows, move air and can put up numbers
stay tuned for moar vids as i get them uploaded
2003 Dodge Ram 1500 - Deep Orange
Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/
Sundown Audio SAX125.2 - Sundown PA 10"
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
Sundown Audio Russia
http://sundownaudio....dex.php?/index
http://www.drive2.ru...ram/ram/skillz/ - more about my truck
http://www.youtube.com/user/Gskillz81
Did you cut the back seats out?
I remember seeing this car on bassclub.ru, but with ski hole.
nah, we just have the seatback out....goes right back in when needed. we had the SA10's in 4th order order in there ported through the ski-pass which was loud and moved major air, but suffered on faster tracks
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
nice
William - Metter,Ga. Dad, Self Installer/Fabricator & Repair Tech, Weightlifter, Motivator,
Team SKAR Audio Captain, Team Deadly Hertz Georgia Leader
99 Toyota 4Runner SR5, "Rolling Thunder"
Daily Driven, No Wall, C-Pillar Build, BASS LIFE!
2K16 SBN MECA Park and Pound DB3 Champion
2K16 SBN ISPLL Real SPL Class F Champion
Second Skin Damplifier Pro, Kenwood eXcelon KDC X498, Clarion EQ, Knukonceptz RCA's
The Big 3, Sky High Car Audio OFC & Kicker Hyperflex Silver Tinned 1/0 Gauge
Singer 340a Alt, Northstar NSB-AGM31, SMSAGM480, 12 NessCaps Super Caps
Rockford Fosgate 3Sixty Line Driver, The Oval Port Tuned To 31 Hz, CNC Machined
4 SKAR ZVXv2 D2 15's, 2 SKAR SK-4500.1's, 4 SKAR PAX 6.5's, 2 SKAR LP-80.4's
MEMBER OF THE YEAR 2013
If you don't have any haters, get some, best motivation there is...
Damn, I must REALLY need a new box because I could only do a 144.9 with 4 of the 12's on 3k.
have you tried other amps? not tryin to shi on AP, but some amps can do rated at 45-50hz, but fail horribly on lower frequencies
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
no you just suck. hardcore. :D
good scores russian folk. and at a nice low freq too
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1891 Guests (See full list)
