MrSkippyJ Posted February 27, 2012 Report Posted February 27, 2012 DD-1 didn't add noise or create your problem. What you need to do is find out where the noise is coming from. *Make sure all equipment is OFF when unplugging RCAs or doing any work to them Unhook RCAs from the amp and see if you still have the noise. Still have noise then it's an amp problem. If not then work your way back to the H/U until the noise is gone. Where the noise stops, there is your problem. Then you just have to figure out what exactly about that piece of equipment is doing to cause the noise. Probably a grounding issue somewhere. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Tebo Posted February 27, 2012 Author Report Posted February 27, 2012 DD-1 didn't add noise or create your problem. What you need to do is find out where the noise is coming from. *Make sure all equipment is OFF when unplugging RCAs or doing any work to them Unhook RCAs from the amp and see if you still have the noise. Still have noise then it's an amp problem. If not then work your way back to the H/U until the noise is gone. Where the noise stops, there is your problem. Then you just have to figure out what exactly about that piece of equipment is doing to cause the noise. Probably a grounding issue somewhere. Do you see where im coming from atleast? Before the dd1 it was fine, after dd1 noise. If there was no ground issue before hand no noise nothing why would the dd1 "aggravate" the noise? There is no noise while the rca cables are unplugged. I just ordered knu krystal cable rca's for my 4 channel i guess they have 4 different types of sheilding. Tomorrow im going to trying to taking out the 4 channel all together and just re install. 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
MrSkippyJ Posted February 27, 2012 Report Posted February 27, 2012 You probably did something when unplugging your RCAs with equipment turned on. There is no way for a DD-1 to create noise in a system, it isn't connected to the system. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Tebo Posted February 27, 2012 Author Report Posted February 27, 2012 All i did was lay them down on the back seat?? Would it be worth a shot to unplug them and make sure they arent touching a ground and let it sit all night? 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
MrSkippyJ Posted February 27, 2012 Report Posted February 27, 2012 I have no idea what that would help. It isn't that your RCA cables are physically touching a ground, but somehow the signal is being directed through a ground. Things happen when you start plugging and unplugging RCAs with stuff turned on. Have you isolated where the noise is coming into your system yet? You already said when the RCAs are not hooked up to the amps the noise is gone. Try turning the amp(s) on with the output side of your EQ unplugged. If no noise, plug them back in and unplug the input side of your EQ. You really need to find out where the noise comes in. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Tebo Posted February 27, 2012 Author Report Posted February 27, 2012 I have no idea what that would help. It isn't that your RCA cables are physically touching a ground, but somehow the signal is being directed through a ground. Things happen when you start plugging and unplugging RCAs with stuff turned on. Have you isolated where the noise is coming into your system yet? You already said when the RCAs are not hooked up to the amps the noise is gone. Try turning the amp(s) on with the output side of your EQ unplugged. If no noise, plug them back in and unplug the input side of your EQ. You really need to find out where the noise comes in. alright ill try it first thing in the morning and post results thanks man. 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
BFF Larry Posted February 27, 2012 Report Posted February 27, 2012 Check grounds at the battery and alt positive connection. Look for corrosion on ground and power wires. Front batt. Back grounding point. Keep the mids amp off and listen for noise coming through the subs. It could also be the amp causing.problems internally. Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
Tebo Posted February 27, 2012 Author Report Posted February 27, 2012 I know for a fact there is nothing wrong the with the the sub amp or the rcas leading to it. Heading out now for some more work its 15* warmer than yesterday so today is the day 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Tebo Posted February 27, 2012 Author Report Posted February 27, 2012 Checked all of my wiring over in the engine bay and back every thing checked out. Unplugged rcas from headunit turned on the amp and there was a very faint noise. Plugged them back in and took the rcas off the amp no sound at all. So im guessing its got to be an issue somewhere around the headunit? I think im going to try a different ground for the h/u 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Rebel4055 Posted February 27, 2012 Report Posted February 27, 2012 Have you tried grounding the RCAs yet? Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
