free box designs with a sketchup pic or file
teardrop
dying to do a sketchup right now... lol if you give me the box specs i'll draw it
lol if thats the case pm me and we can get started on another box! :twirl: and lets see what OP can do here... 2003 ext trailblazer 2 18" dc xls sundown 3k 46w x 38d x as high as you want.. looking for a box kinda like meade's with an interchangeable port...
wher do you perfer subs and port whats the displacment of subs
Subs up port back
whats the sub displacement
.4 total...
sorry i cant do the changable port but can do o 10 cub box tuned to 33 hz with 14.84 port per foot subs up port back ill do that if you want
DC level 4 with level 5 upgrades 10"
Mounting Depth 6.25"
Mounting Hole Diameter 9.25"
Outside Driver Diameter 11.0"
Motor Width 7.75"
Weight 32lbs
VC Diameter 3"
Displacement .16³ ft
Magnet Weight 29lbs
Power Handling RMS/Peak 1400/2800 2000/4000 w/ upgrade
Ohm wired at 1
Sd
Vas
Cms
Mms
Fs
BL
Re
Le
Qms
Qes
Qts
Xmax 23.5 mm
Ref SPL @ 1 watt
Suggested Sealed .75³ ft
Suggested Ported 1³ ft
My amp is a atomic 1000.1
Max demintions
Width 57"
Height 18"
Bottom depth 8"
Top depth 4.5"
I know you said you liked to do big boxes but if you can point me in a vicinity I'll be happy.
Thanks
I have one SoundStream SPLX-HF 15". Running on two SoundStream TX1.1300D (one per coil) going to seal off from trunk. I want sub and port facing forward. It is going in a ford contour. Max dimensions are 39w X 31L X 22H Specs on sub are: series wired SPLX-152HF Fs (hz) 35.96 Qms 6.476 Vas (ft³) 87.56 Cms (mm/n) 0.0794 Mms (g) 247.1 Xmax (mm) 13.00 Xmech (mm) 19.50 Piston Diameter (in) 13.19 Sd (in²) 136.6 Qes 0.503 Re (Ω) 2.95 Z (Ω) 4 BL (Gauss) 18.09 Rms Power (watts) 1,250 Qts 0.467 NO (%) 0.78 1w/1m SPL (dB) 90.95 Voice Coil Diameter (in) 3" Impedance (Ω) DVC 2Ω M-vd (ft³) 0.298 Measurements SPLX-152HF Overall Diameter 15.25 Overall Height 9.25 Mounting Depth 8.375 Cutout Diameter 14.125 Motor Diameter 7.875 Motor Height 3.5 Flange Width 0.75 Flange Height 0.625 Weight (lb). 35 I want tuned to 31 hz
i need your displacment of subs
.5 ft^3
2 10's ALPINE TYPE R's
Dual voice coil 4ohm
600 RMS
1800 Watts Peak
Frequency Response 26Hz-200Hz
My max demensions are 33W x 15T x 20D
Amp is a BOSS PHANTOM PH5000D 1800 RMS
Subs are going to be wired down to a final impedance of 1ohm.
i want a ported box with the port firing towards the trunk.
tuned to 33Hz
Mounting Dept:149 mm (5.875")
Mounting Diameter - Front Mount: 231 mm (9.1")
Displacement - Front Mount: * 0.080 ft
Added Volume - Reverse Mount (magnet out)* 0.055 ft 3
External Box Dimensions:12.5" x 12.5" x 20.5
Gross Internal Volume 1.4 ft
Vent Area (dimensions)11 in 2 (11" x 1")
Vent Length: 18.5
Vent Displacement 0.24 ft 3
Net Internal Volume (Vb)*** 1.1 ft 3
F3, ripple, Fb: 28Hz, 4.5dB, 35Hz
Sensitivity (SPL@1W/1m)* 83dB
Free Air Resonance (Fs: 31Hz
Equivalent Stiffness (Vas)21L (0.75 ft3)
Mechanical Q (Qms) 7.9
Electrical Q (Qes) 0.57
Magnet Weight: 128 oz
Xmax (One-Way Xmax @ 10% Distortion) 20 mm
Mechanical Excursion, Peak-to-Peak: 70mm
Gap Height (Hag) 10 mm
Coil Height (Hvc) 44mm
Cone Area (Sd) 332 cm2
Voice Coil Diameter: 65 mm (2.6")
I already got everything done, I just need to verify it before I get the wood, so I'm gonna post the stats and the box design on here and if you can give me some feed back, it'd be nice....Since no one replied on my own thread and I ain't going to bump it.
Two 12" level 3 DC audio with level 4 softcones.
Recommended volume for both subs is 3cu ft (1.5cu ft each) Want it tuned to 32hz.
Any fixes will be appreciated. If it isn't necessarily, I appreciate your input.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
you accounted for bracing in the calculator, but there is none in the sketchup. single dowel or threaded rod going from mid baffle to back wall should suffice
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
yeah I know lol. I was at work and I got posted in another location and had to shut my laptop down.
i personally like to add 45's in certain corners for efficiency, but this should work fine
More box builds
Oh I see what you're talking about...but I suck horribly at making 45s lol, unless I take it to a precision table =( But other than that, does the calculation look alright, that's what I'm really concerned about
looks like you could get port noise from such a small port 3.5 in i dont like going below 5 in on slot ports and 4 in on round ports
  • Who's Online   0 Members, 0 Anonymous, 1027 Guests (See full list)
