free box designs with a sketchup pic or file
teardrop
Any updates on these? lol
Does the port have a bend in it? Or a triangle in the back of the port
no just a streat port
aero ports are simple do a circle with a bigger circle on outside the distance of the flare out then strike an arc and then go to follow me and follow circle and done
R.I.P!
(Nov-29-2009)
92 explorer
current build
nice ill try that thanks
I would at least put a triangle wedge to direct the air flow better
any updates.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
2 18" blaupunkt subs 5400watts max 1800 watts rms going to be running at 1500rms
want the box to be tuned to 30 to 35 hertz please struggling with the size help!
vpw 460s?
off topic but ive really seen those get down.
Not too popular in this forum.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
I've got 4 spl audio sp3 dual 2ohm 12's. 1000watt (Rms pair)
I have 2 punch T 1500 amps if needed to power them. I'm looking for a wall with the port & subs facing forward .
Max dimensions : 4ft wide 3ft tall & deep as needed. Thanks
subs make model: 4 sundown e8 v.2s specs:RE: 6.12 ohm Fs: 44.7 hz Qes: 0.5456 Qms: 3.6545 Qts: 0.4748 Le: 4.02 mH Vas: 7.26 L BL: 17.45 NA Cms: 131 uM/N Mms: 96 grams Sens: 82.59 1w/1m Xmax: 10.5mm one-way linear RMS: 200 watts ported cuft^3: .5-.6 displacement: .05 each cutout: 7.25 amps make and model: sundown 1500v.2 at 2 ohms max deminsions:37x14x36 subs and port direction: forward
i hade to do round ports but let me know if this will work its 2.45 cubic after dis tuned to 33 hz 10.26 in of port per cub ft and its double baffle
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
