so my stinger volt meter is all screwed up and shit, does anyone have experience or anything with the new stinger volt meter with the usb charge?
its on darvex, it looks really good but is it as good as the normal ones
Its the one that plugs into the cig lighter right? If so its probably not very accurate. You might be able to hardwire it to the amp and get better readings. If its just not working right then I'd send it back.
ok, because it reads like 13 and low 12s when i put a dmm on my battery and it reads 14 volts and it will sometimes work but it doesnt last for long lol
ok, what about this one
why the hell cant i copy n paste shit, dammmit. ok well its the xscorpion 3-digit blue led digital volt meter
That voltmeter will work fine as well the only reason I spent more money on the stinger one was because that scorpion is so dam big
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
how many times do you have to be told to post things in the right section?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
This topic is now closed to further replies.
