My friend gave me his sub to look at and see if its fixable its a rf p2 its and 8 ohm svc model. Anyway he dropped it one day and it quit working. I pushed down on it and its rubbing really bad it hardly moves unless you push down hard. I think its coil rub can thia be fixed if not it will have to be trashed I don't think there are recones for it.
What size is it?
Cause I'm seeing recone kits for the P2 on ebay ranging from $12 to $22 depending on size.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Damn, ebay only has recones for 8', 10', and 15' and the only 12' recone is for the Punch HE.
2003 Kia Sorento
Team Subsonic Lows
Is there anyway if I'm really careful cutting I can reuse the softparts after fixing the pole piece or is there anyway to take off the magnet without removing the softparts?
Once you disassemble, the existing soft parts will no longer be useable.
Once dropped, you most likely ended up with a bent frame or shifted motor. This may not be fixable by yourself.
P2s arent that expensive and its probably a more economical solution to just buy a new sub.
If you want to try and fix it just for fun, take a knife and start cutting the surround and spiders and pull out the cone/coil assembly so you can assess the damage. Then go from there.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
trash it
Duel Sa-8 V.2 D2 Sub Enclosure
2001 Pontiac Grand am
  • Head Unit - OEM
  • Processor - RF 3sixty.2
  • Subs - RE Audio SXX12D4
  • Amplifier - Kicker ZX1000.1
  • Mids & Highs- Rockford Fosgate Power T2652-S
  • Rockford Fosgate Power T1693
  • Mids & Highs Amp - Rockford Fosgate Power T400-4
  • Wiring - 1/0 AWG, 4 AWG, 8 AWG
  • Alternator - Stock
  • Batteries - non ext
  • Box- Absolute PSEB12BK
  • Who's Online   0 Members, 0 Anonymous, 1569 Guests (See full list)
