I'll post for him.
The amp is a Jensen 5500 5 channel and will have 250 watts between the pair / 125 watts each
try this
outer dims
11 tall, 35 wide, 16 deep
slot port w/ 3 common walls
9.5 high, 3 wide, 26 deep
this accounts for .05 cu ft for bracing
gives you 14.5 sq inches of port per cube
i know you wanted aeros, but this will be a little easier to make
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
well shit... gonna have to make the box a little bigger... or step your amp game up a little :P
with that amp go with this
outer dims
13 tall, 37 wide, 16 deep
11.5 high, 3.25 wide, 24 deep (20" physical port length)
gives you 15.5 per cube with .05 for bracing
35 hz tuning
More box builds
125 before Impedance rise, on 2 400 watt 8s, I'll consider a t-line for them with that power .
or this ^^
i could do a t-line for you if you'd like
More box builds
Here are the specs for the Skar VVX-8:
http://skaraudio.com/index.php/products/vvx-8/item/vvx-8-subwoofer.html
Hard to believe but their net volume range for ported is 1-1.4 cubic feet per sub. So here is a suggestion within your dims:
Enclosure Specifications:
Fb = 36.12 Hz
Vb = 2 ft^3
External Height = 13 in
External Width = 29 in
External Depth = 16 in
Port Width = 2 1/4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 26 x 11 1/2
Back = 29 x 11 1/2
Left & Right Sides:
Side 1 = 14 1/2 x 11 1/2
Side 2 = 15 1/4 x 11 1/2
Top & Bottom = 29 x 16
L Port Internal Assembly Parts:
Front to Back = 12 1/4 x 11 1/2
Extension = 5 7/16 x 11 1/2
Just did a t-line for 1 8 using dimensions pretty close to what the op has. won't fit w/o being tuned retardely high.
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
