but the magnet shifted off a little bit by like half a inch
Align it back as good as possible, push down on the cone and see if theres any coil rub. Then tape the shit out of it lol.
Yeah its rubbin like crazy Im thinking about grabbing a rubber mallet and bumping it back into place
Shit happens, if its yours then rig it too work best you can. If its someone else's however, you should replace it. Careless installer is still a responsible installer, I would be pissed if someone dropped my shiz and then duct taped it. You can align it with bar clamps, then CA glue best you can.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
nahh its my btl I would not even be on here if it was someone elses
Did you drop it? Duct tape that shit.
lol duct tape fixes everything!
that sucks man.....
Electrical tape is what I used on a Q that was cracked all the way around, and could rotate it around. Its still playin to this day :) As long as you dont get coil rub it should be fine.
or you could just try and CA it all the way around. just try and avoid coil rub as stated before
I Got the magnet centered and tested the coil to see if it was rubbing together so after testing I put a layer of jbweld around the crack of the magnet and now im going to wait for it to dry to tape it. I will give you guys a update tommorow cross your fingers !!
That sucks so bad! It would drive me to replace it if it was my sub. I would probly play it til I could replace it. But it would worry the shit out of me just because.
I don't think it's going to have nearly the motor force it did before...
this
i can't imagine the flux is the same either
Edited by Decaf
lost some motor force, but will work fine for the most part. Glue the crap out of it and have fun while it lasts..
wish "high" end manufacturers would bolt the motors together so this shit wouldnt happen.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1426 Guests (See full list)
