PCM Coltrolled Alt Voltage Adjustment?
Vehicle is a 2010 wrangler. The alternator voltage is controlled via PCM and currently charges at 14v.
Does anyone know how to 'fool' it into charging at a higher voltage? Or am I stuck with whatever it deems the charging voltage should be?
Edited by SnowDrifter
mla mod i think, most jeeps and some chrysters are the same, actully charges at 13.6 or so
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Do you know where to find them? I've been poking around with no luck :(
here is their site: http://www.missinglinkaudio.com/id24.html
The MLA will set off the check engine light on most applications so just a heads up but it will run just fine. Meade had a MLA before he got the xs power VCM for his tahoe and his MLA made the check engine light come on and stay on, the xs power VCM had corrected his check engine light.
My trucks also got a pcm mechman 270. I get it charges at a lower voltage like 13V right? But whats it mean realy? At 14+v it will charge my batterys faster right? But at 13 it will still charge just over more time? How much more anyone wana take the time to explain it to me plz. Im runing a dc.5k and.a hifonics 150w@4 ch for highs . For batterys I have a stock and a d3400 under the hood. And just got my 2 xp3000.
If your mechman alt has a AVBM harness and you set the pot to a certain voltage I think it is tricking the PCM? Theres a 1 volt difference so naturally it would charge a bit faster. I would just do without the stock battery if it isn't a agm battery also.
about the check engine light I'm at a loss on that at the moment. I would rather not "fool" the PCM and just let it do what it wants to do naturally. this is where I'm stuck at personally.
  • Who's Online   1 Member, 0 Anonymous, 1352 Guests (See full list)
