Confessed Posted March 13, 2012 Report Posted March 13, 2012 Skar VVX12 D4 wired to 2ohms Soundstream Rubicon 1600w Kenwood Excelon KDC-X395 When I go to set my gain with a 50hz tone playing, I see very low voltage even when the gain is up higher than it should be. Gain up almost all the way and I'm not even seeing 500w. Subsonic is set to about 25, lpf at about 80. No bass boost. Battery voltage lowest drop I've seen is 14.0. Subwoofer lvl on the headunit is at max as it should be. Volume set to ~27 out of 35 max. Knu 4ga power and ground. The input voltage selector is at 2-8v instead of .1-2v because of my 4v preouts. I'm assuming this is how it should be. Help me out, guys!
Slapuhho Posted March 13, 2012 Report Posted March 13, 2012 Skar VVX12 D4 wired to 2ohms Soundstream Rubicon 1600w Kenwood Excelon KDC-X395 When I go to set my gain with a 50hz tone playing, I see very low voltage even when the gain is up higher than it should be. Gain up almost all the way and I'm not even seeing 500w. Subsonic is set to about 25, lpf at about 80. No bass boost. Battery voltage lowest drop I've seen is 14.0. Subwoofer lvl on the headunit is at max as it should be. Volume set to ~27 out of 35 max. Knu 4ga power and ground. The input voltage selector is at 2-8v instead of .1-2v because of my 4v preouts. I'm assuming this is how it should be. Help me out, guys! I wouldn't have your sub level on your headunit maxed out, causes a bad signal. 4 18's, low power and lots of gay fur. Team gg Team DOA My Videos
CleanSierra Posted March 13, 2012 Report Posted March 13, 2012 Skar VVX12 D4 wired to 2ohms Soundstream Rubicon 1600w Kenwood Excelon KDC-X395 When I go to set my gain with a 50hz tone playing, I see very low voltage even when the gain is up higher than it should be. Gain up almost all the way and I'm not even seeing 500w. Subsonic is set to about 25, lpf at about 80. No bass boost. Battery voltage lowest drop I've seen is 14.0. Subwoofer lvl on the headunit is at max as it should be. Volume set to ~27 out of 35 max. Knu 4ga power and ground. The input voltage selector is at 2-8v instead of .1-2v because of my 4v preouts. I'm assuming this is how it should be. Help me out, guys! What car do you have? Is this with the car on or off? That amp isn't gonna push HUGE power at 2 ohms(especially after box rise). The vehicle and grounds of the amp are the biggest two factors I think are important here. Im not the one you want to try to troll. Just a fyi for you.
littlebuck1919 Posted March 13, 2012 Report Posted March 13, 2012 and how true are the ratings? i never heard how close the ratings are for soundstream amps? Feedback Thread: http://www.stevemeadedesigns.com/board/topic/152368-littlebuck1919s-feedback/#entry2177586 i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol 6/18/82 - 4/17/12 R.I.P. to my sister Shana
Confessed Posted March 13, 2012 Author Report Posted March 13, 2012 I wouldn't have your sub level on your headunit maxed out, causes a bad signal. It's different on this head unit. You literally have to use it it get output more than like 70watts lmao. What car do you have? Is this with the car on or off? That amp isn't gonna push HUGE power at 2 ohms(especially after box rise). The vehicle and grounds of the amp are the biggest two factors I think are important here. 94 prelude. Car on. My grounds are all fine. And 1100w at 2ohms sounds good to me. I don't plan on running it at more than 800w though. I CAN'T EVEN GET 600 THOUGH FFFFUUUUUU. and how true are the ratings? i never heard how close the ratings are for soundstream amps? They're accurate from what I've read. I was told that this is one of the better ~1500w amps if you can get it for ~$170 or so, which I did.
CleanSierra Posted March 13, 2012 Report Posted March 13, 2012 I wouldn't have your sub level on your headunit maxed out, causes a bad signal. It's different on this head unit. You literally have to use it it get output more than like 70watts lmao. What car do you have? Is this with the car on or off? That amp isn't gonna push HUGE power at 2 ohms(especially after box rise). The vehicle and grounds of the amp are the biggest two factors I think are important here. 94 prelude. Car on. My grounds are all fine. And 1100w at 2ohms sounds good to me. I don't plan on running it at more than 800w though. I CAN'T EVEN GET 600 THOUGH FFFFUUUUUU. and how true are the ratings? i never heard how close the ratings are for soundstream amps? They're accurate from what I've read. I was told that this is one of the better ~1500w amps if you can get it for ~$170 or so, which I did. HOW do you know what kind of watts you're getting? Are you doing a clamp test or something? Tell me this isn't just a guess thing. And just so you know, most of those eXcelon head units can go almost near the max volume with no clipping. 33-34 is PROBABLY safe. I always ran mine at 30 or 31 and was comfortable listening there. Im not the one you want to try to troll. Just a fyi for you.
Confessed Posted March 13, 2012 Author Report Posted March 13, 2012 HOW do you know what kind of watts you're getting? Are you doing a clamp test or something? Tell me this isn't just a guess thing. And just so you know, most of those eXcelon head units can go almost near the max volume with no clipping. 33-34 is PROBABLY safe. I always ran mine at 30 or 31 and was comfortable listening there. DMM + math is how I know the watts. I'm not THAT dumb, bro. I wouldn't just guess after putting a lot of money(to me at least, not most of you guys lol) into something.
n8ball2013 Posted March 13, 2012 Report Posted March 13, 2012 HOW do you know what kind of watts you're getting? Are you doing a clamp test or something? Tell me this isn't just a guess thing. And just so you know, most of those eXcelon head units can go almost near the max volume with no clipping. 33-34 is PROBABLY safe. I always ran mine at 30 or 31 and was comfortable listening there. DMM + math is how I know the watts. I'm not THAT dumb, bro. I wouldn't just guess after putting a lot of money(to me at least, not most of you guys lol) into something. Except its completely inaccurate and is onyl used be people to cheap to understand a clamp meter is needed. Also by a bunch of people who claim to know what they are doing. Face it you need a clamp to know how much power you are getting. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Guest Posted March 13, 2012 Report Posted March 13, 2012 a DMM is worthless to an everyday mans use for an amp. its only good for reading the input voltage coming from the battery. unless you're an amp repairer, that's all that its useful for.
BeAlLsTaR13 Posted March 13, 2012 Report Posted March 13, 2012 Skar VVX12 D4 wired to 2ohms Soundstream Rubicon 1600w Kenwood Excelon KDC-X395 When I go to set my gain with a 50hz tone playing, I see very low voltage even when the gain is up higher than it should be. Gain up almost all the way and I'm not even seeing 500w. Subsonic is set to about 25, lpf at about 80. No bass boost. Battery voltage lowest drop I've seen is 14.0. Subwoofer lvl on the headunit is at max as it should be. Volume set to ~27 out of 35 max. Knu 4ga power and ground. The input voltage selector is at 2-8v instead of .1-2v because of my 4v preouts. I'm assuming this is how it should be. Help me out, guys! I wouldn't have your sub level on your headunit maxed out, causes a bad signal. his HU doesnt clip even at full volume with sub level all the way up, my buddy has the same one and owns a DD-1, only time it clips is full volume with sub level maxed out and bass setting hits +2. on the kenwoods the subw setting being maxed is only way to get full preout voltage OP, could it perhaps be out of phased? wired backwords? most of the time it can cause a setup to be less effective. IMO, i'd throw the DMM away and set your gains by ear.. its a small power setup so youd be able to get away with it i think. ive noticed since ive had my 9887, every amp i threw on it liked the gains roughly around 2/3 or so, which is also a 4v preout. aim for that and see what it gets you one other thing, what type of box and specs are you using? Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
