Tarball Posted March 16, 2012 Report Posted March 16, 2012 press f8 when windows first starts to boot you need to disable system restart on sytem failure so you can see the blue screen code you are getting CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
n8ball2013 Posted March 16, 2012 Report Posted March 16, 2012 It does that after you hit last known good configuration? it sees your drive. Im wondering if its got a bad cmos battery and it doesnt know its supposed to boot from the drive. Good point. I don't deal with PC's much anymore. if it was the cmos batt, it would have him press F1 to continue before it went past the POST. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Berto Posted March 16, 2012 Author Report Posted March 16, 2012 and you CAN NOT hit the "Safe mode" option? correct? No, the same thing happens. I just went to Autozone to get some fuses and recorded a video. It's uploading at the moment, YouTube says 10 more min till it's done. TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
Sheena Posted March 16, 2012 Report Posted March 16, 2012 well in the blue screen its basically going to tell you that its blue screening due to a recent hardware or driver change, then dump the memory to the HDD.. two things to try that have like a 98% success rate.. pull the computer out of wherever its at and blow the dust off of it, VERY CAREFULLY make sure that there is NO DUST inside the ram slots (where the ram plugs into). its VERY COMMON that the dust gets into a pci-e slot or ram slot and prevents the BIOS from passing the power test, which blue screens. the other option is the windows xp disc, you will NEED TO KNOW your operating system in order to get the proper disc. 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Berto Posted March 16, 2012 Author Report Posted March 16, 2012 Here's a vid of everything that happens: TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
Sheena Posted March 16, 2012 Report Posted March 16, 2012 press f8 when windows first starts to boot you need to disable system restart on sytem failure so you can see the blue screen code you are getting follow these steps and see what happens. also dont be afraid to spam f8 until the screen shows up with advanced options (the computer still wont work, but it offers important diagnostic information that will be helpful in solving the problem) 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Berto Posted March 16, 2012 Author Report Posted March 16, 2012 press f8 when windows first starts to boot you need to disable system restart on sytem failure so you can see the blue screen code you are getting follow these steps and see what happens. also dont be afraid to spam f8 until the screen shows up with advanced options (the computer still wont work, but it offers important diagnostic information that will be helpful in solving the problem) I got the 1st black screen PLUS: Enable Boot Logging Enable VGA Mode Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Disable Automatic Restart on System Failure Reboot Return to OS Choices Menu TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
Sheena Posted March 16, 2012 Report Posted March 16, 2012 "disable automatic restart on system failure" is the one your after 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Berto Posted March 16, 2012 Author Report Posted March 16, 2012 I clicked that, now I'm on this screen: TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
Sheena Posted March 16, 2012 Report Posted March 16, 2012 you will be needing a windows xp disc for the next step lol. do you know what operating system is on there? xp? vista? 7? 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
