1991 pickup 2wd 22re fuel injected toyota sits on 15" tires and rims. low profile.
Truck has sat in yard for 10 years runs now but ithink it runs a little rough looking to gains some Gas mileage (MPG)
new:
Fuel Filter
Fuel Pump
Fuel Tank
Spark Plugs
Spark Wires
Cap & Rotor
Oil Filter/Oil Change.
Air Filter
PCV Valve
and Belts.
Air Flow Meter tuned and idle to
also i have ran Sea Foam Through the Vacuum and gas Tank.
any advice?
How's the ignition timing on it? Is it set to OE specs or is it off? Plugs were gapped correctly? Wires in all the way? What gas do you put in?
my 91 (194k miles) recently snapped a timing belt. May want to look into that!
Timing BELT? :puzzled: a 22RE uses a single roller timing chain.
These trucks honestly don't too great on gas to begin with, as for the running rough since it sat that long did you pull the injectors to make sure they are all clear? Otherwise you seem to have hit all the bases I'd start with. If so I'll dig deeper.
Edited by 727Designs
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
  • 4 weeks later...
wow i forgot to respond to this so long ago
since then i have ran some sea foam through the system cleared it out good bit
flushed radiator
got timing fixed
valves adjusted
new thermostat
next thing is timing chain.
but i got 28 mpg and its runs great. towed a 3500 pound trailer on it the other day handle it with no problem
and reason for bad gas mileage is timing was dead center when it needed to be -6 degrees so after it warms up it goes dead center and idles at 750
Post pics? :D
2010 F150 FX4
-18" AA Mayhem
-Crescendo BC3500d
-Pioneer GM-D9500F 4-channel
-2 Crescendo FT1
-2 Crescendo Neo Forte 6.5
-Pioneer AVH-P3300BT
-6000K HID Headlights/Fog lights
-All LED interior lighting
-20% tint on front windows, 1% rear windows, 5% windshield strip
-Big3 (XSFlex 0ga)
-DC Power 270XP
-Group 65 NorthStar AGM battery
Coming soon/plans:
-Build log
-Blacked out mirror reflectors
-Tinted tails/3rd brake light
