WakingJudea Posted March 21, 2012 Report Posted March 21, 2012 just installed a 270 mechman alt, d6500 up front, 2 xp3000 in back, one bc3500 at .5 ohm tuned with dd-1, one run of pos and neg to the back and im dropping into the low 12s at full tilt. the amp leads to the batterys are 4ft long if that matters and neither of the xp3000 are grounded in the back (i dont really want to drill holes in trunk if i can help it) would adding another run or 2 of neg to the back help? the subs are 4 chaos 15s d1's for anyone wondering.
getlocivic Posted March 21, 2012 Report Posted March 21, 2012 def do another positive run and double up the grounds
carlosg_313 Posted March 21, 2012 Report Posted March 21, 2012 That is weird....I only got a xs power d3400, d3100 and a dc alty, with just one run of pos and neg wire(knukonceptz), 4ft run of kicker wire to the back battery and 3ft to neg post of back battery, had it wired to .5ohm and only dips to the 13.5-13.8.....maybe another run of wire would help a lot. How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman
AA98hoe Posted March 21, 2012 Report Posted March 21, 2012 Did you do big 3? And ground batterys in back just to be sure.. I have multiple grounds front and back to frame plus 5 0g runs front to back TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
WakingJudea Posted March 22, 2012 Author Report Posted March 22, 2012 yea i did the big 3, so it looks like im going to add a couple more runs to the back to see what that does. thanks guys.
n8ball2013 Posted March 22, 2012 Report Posted March 22, 2012 im not so sure whats difficult about the fact that you are running your amp at .5. If you are running your amp hard im willing ot bet you have in the neighborhood of 500 amps of draw. You only have enough reserve for a short time. This is why I do not advocate for every tom dick and harry running their amps that hard. They all think that its magical to do so and then fail to realize that current draw goes through the roof and output is a couple hundred watts more. It's just not worth it in most cases. You're beating the shit out of your alternator THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
WakingJudea Posted March 22, 2012 Author Report Posted March 22, 2012 ive got a 2nd 3500 i want to install so if i strapped them together would i be able to get a final load of 2 ohms out of them with 4 d1's?
MuRKRoW Posted March 27, 2012 Report Posted March 27, 2012 Wire the coils in parallel and the subs in series. That will give you a 2-ohm load. Here's a pic to help you wire them: Sound Solutions Audio ZCON 18 Crescendo Audio BC3500D JVC KD-R80BT headunit Alpine/Pioneer mids & highs 4 group 34 agm batteries Knukonceptz 3x0ga. terminals Kicker/XS Power 0ga. wiring
