Does anyone know where to find a switch that can handle 400 amps VDC? I have a 390 amp alternator and want to shut the wire off going to my 9 battery bank of batteries so the alternator can power my front battery. I have a switch for the front battery to turn that off when I want the alternator to charge the 9 battery bank. Anyone know where to find a 400 amp switch for DC?
why not do what everyone else does and charge your front as well as the rears. are they 16volt in the rear or anything like that or all 12 or 14 volt?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Maybe a marine battery selector... stinger solenoids etc only go up to 200 amp
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I don't want to charge the front with it because my back batteries sizzle because the other two alternators overcharge them. Plus it's a bad idea to have a 8,000-14,000 watt amp draw power from the front. The marine switches are like $80-$180 and seem to high for what they are. I found a tractor battery cutoff switch rated at 100 amps, which would work for the front battery, but every 400 amps is like a home switch box or like in the movies where the guy puts a wrench in the fuse and lifts the huge lever. I don't want to use a circuit breaker because it will trip. The breakers are not like fuses. The breaker trip when too hot and a lot of current will trip it, which is why car buffs don't use them anymore.
What about a couple removable 200A fuses?
You really don't want to make or break a switch that large while the current is flowing. It'll arc like crazy and corrode the switch.
You'd also be introducing extra resistance in the main current path. Any extra resistance at that current level will heat up and cause a pretty good voltage drop.
Not a big deal on a 120Vac circuit which can handle a couple volts of drop, but that adds up quick at 12Vdc.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
You shouldn't have any overcharging issues unless your voltage is whacked out. In which case, fix it, don't bandaid it.
I guess We are all doing it wrong. My batteries dont sizzle thoguh.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
None of my batteries sizzle either, and i have 930+ amps of alternator charging going to 3 batteries, and not even a stereo in the truck at the moment to drain the batteries..
You really need to check out your issues in your vehicle before you do something to cause even more damage!
  • Who's Online   1 Member, 0 Anonymous, 1200 Guests (See full list)
