What can you learn from the subs specs? Can you tell if it's more of a sq/spl sub? What can help determine a all around sub compared to one thats strictly spl for example? This may be a dumb question or may not even be possible but there are sub specs that I look at and have no idea what they mean.
These are a few I am curious about and are taken from my RE XXX 15".
  • Force Factor -Bl: 18.16
  • Electrical Q Value -Qes: 0.58
  • Mechanical Q Value -Qms: 3.62
  • Total Speaker Q Value -Qts: .501
  • Free Air Resonance -Fs: 19.10 Hz
  • Equivalent Compliance -Vas: 207.0 liters
  • One-Way, Linear Excursion -Xmax: 54 mm
  • Efficiency - SPL 1W/1m: 85.81 dB SPL
  • Effective Piston Area -Sd: 810 cm^2
54mm one way xmax! am i reading that wrong? that is over 4 inches of total throw i do not believe that.
NEUMAN
No you read that correctly.
Ive had 3 of the XXX12D2's.
They flex a MASSIVE amount.
by the way o/p, XXX woofers are SQL not SPL
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
NEUMAN
Ty sir, did not know that. I feel like the sub gets loud but only on certain songs. Coulda been the way I made the box too though
NEUMAN
it does get very loud especially for an SQL speaker
From my experience with them, the 12's like ~4^3ft before displacement, and need at least a 4" wide port to breathe properly.
My box was tuned to 32.9hz, at loved frequencies in the range of 25-40hz, but would redoing to 70hz and less.
goodluck with yours :)
I blew my last XXX out this afternoon, and am now woofer-less :'(
Let me know if you need any more info on the XXX series :)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
NEUMAN
WOW. i will have to look in to them a bit.
NEUMAN
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
