depends on your subs and impedience,
if you strap you only have to set gains and all on one amp but you usually have to have a 2 ohm load.
if you go with two seperate amps you can usually go to 1 ohm but you will have to gain match the amps
now i'm not saying it isnt possible to go lower, but i dont think its recommended
Edited by bass_stalker
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
some people have told me that unstrapped they gained
but i have yet to see any proof
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
some have also said strapping them gained-
there is many variables when it comes to things like this
R.I.P!
(Nov-29-2009)
92 explorer
current build
exactly you will find people that have gained strapped or gain seperately no situation is the same.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I've got the DD1 so the gain matching isn't a problem. Both subs are dual 2 and the amps are 1ohm stable each/2ohms strapped so I can run it either way. I might just swap things around and run them separately just for the hell of it. Won't take much more than a phone cable splitter and 10 minutes with the DD1
DD-1 is not a gain matching tool.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I ran strapped for over a year then started having issues..of course I strapped real low also... didn't see a gain unstrapping but solved my issues
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 2379 Guests (See full list)
