Started shimming up my woofers to recone them and Im wondering just how much is too much gap. Ive got the whole coil shimmed evenly but it doesnt seem like its very tight. Its also stupid hard to get a picture of. If I really try to I can move the coil all the way in one direction and I'm able ot create a slight gap on the opposite side. Im talking paper thin. Is this going to induce coil rock?Im going to assume once its glued down that will go away but id rather not find out the hard way.Im assuming since its shimmed evenly all the way around it wont be an issue. I just see guys on youtube cramming the hell out of their coil gap and I can barely fit one layer. recones arent cheap for these things.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
DD sent me shims to use. Its a clear vinyl sheet. I can get one layer the whole way around and thats it. even if I push the coil one way it doesnt create enough space to stick another layer in one side even.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Can you fit something like a piece of printer paper in there?
It should be fine...as long as it's shimmed even all the way around
I like to use just white printer paper cut down to size. It might take alot of sheets but you can keep adding little by little until it's just right
Team Flex Issues
no. not all the way around I dont think. Its a tight gap to start with.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
thats my thoughts. but 140 bucks a recone adds up quick.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
as long as its even your good the spiders is what keeps the coil linar when the spiders start to get really lose is when you start to get coil rock
yeah I just tried and I cant even fit a piece of paper all the way around the pole.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 451 Guests (See full list)
