You could just half-ass the chasing of the wire... But it won't completely eliminate the chance of the problem being there.
Could just take the bulb out, put the DMM leads into where the bulb goes, start shaking the wiring harness and watch for a change in voltage.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
HOTDOG! I need help. Just found this when trying to run wire for the door speakers. This is by far, the fucking dumbest thing I have ever seen. :madsign::soapbox::jon:
Looking from the inside of door. No problem, right?
From inside of the B pillar :jon:
Now what the fuck am I supposed to do with something like this?
How am I supposed to run wire around that big piece of shit? :jon::soapbox::madsign:
Only thing I can think to do is drill out a couple of the empty holes on the plug or something and try to shove the wire through, but that might not go well.
This is what I did. Pull the harness out and take a drill bit and drill a hole about the size of your speaker wire along the edge of the metal where the harness goes. Now start cutting away some of the plastic on the harness so the speaker wire can fit into the groove you want the speaker wire to be half into the metal and half into the harness. This way when you run the wire the boot will cover it up and you wont see anything.
and yea it is crazy how they are doing doors like that now in an attempt to stop people from running wire into the doors.
See where the groove is in that harness in the middle. That is where my wire runs through.
Hmmm, maybe my wire will fit in there.... just at a glance, my first thought is that it wont fit. Guess I'll try at least, would be a lot less work if it fit.
it was a tough job and the angles you have to work at are difficult but I bet your determination will get the job done. It took me at minimum 30 min per door because I did not want to damage the door or harness.
