mine has worked day in and day out. never complained when it would get hot as fuck to the touch in the summer. never protected on me
Does the kicker just run hot in gerneral, or do you have good grounds, good voltage, good wiring, too much gain? That is what i would be looking at. AQ amps are good from what I have read, but not sure if you want to just swap out kicker for AQ.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
"Just wondering the opinions about the quality of kicker amps compared to the aq line of amps." that is clearly a vs question. comparing = vs.
before a mod gets in here hopefully someone will help you. all i can say is i ran my AQ1200D at .5ohm through last summer and it pounded all day everyday no problems and sounded good doing it. they really are a great product. Only reason i got rid of was because I got a connection with DD and get good prices. But my friend still bumps that AQ1200D @ .5ohm and sounds good in his car now. good amps for the price
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
AQ .... have not had any prob's with my 1200d.1........it's a beast for a 1.2k............
  • Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO
Pioneer DEH-3400-UB
Vega 65 cs & 1" tweets & T3 4" coax in Front
1- Dual 300 with an AQ sticker
2-AQ sdc2.5 12's
1- AQ 1200D.1
Monster Cable RCA's
Monster Cable 4-awg
Custom 4 th order box ( by DBC )
Crescendo FT1's in rear- 1/0 Big Three
Opti Blue top in back for Mono Amp
Stinger Power dis. block
125 amp breaker at front batt.
Stock Alt.
co worker of mine has aq amp and loves it and never had a issue in well over a yr and he uses it daily
Edited by fosgatefan821
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
I ran an aq 1200 then bought a second to strap them, then switched setups again and bought an aq2200 then a second and strapped them never had problems with the amps only issue I ever had was the connection on the gain knob became bad on one cord or the knob itself but since I had 2 amps I switched it out and called aq and then sent me a new one anyway. Pretty minor the aq amps put out pretty good power and perform well especially for the prices. If you have proper wiring (size and grounds) it shouldn't overheat. But the only experience I have with kicker amps are2 friends of mine one had a 400.1 and one had a 750.1 both seemed to run on the warmer side but I can't vouch for wether or not my friends were clipping by just cranking the gains. The 400.1 lasted about 5 years the 750.1 about 2-3 then he sold it so I don't know where it went.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
