AA98hoe Posted March 31, 2012 Report Posted March 31, 2012 You say 2 3500s strapped at 1ohm so that's .5 per amp..depending on box your rise is going to affect wattage..I wire at .35 each and rise to 10hm because my box is on the small side 16cf for 4 -18s...so let's say in a perfect world 7k on 12v..id do ascendant havocs you won't have enough power for mayhems unless you plan to upgrade...do 4 -15s and common chamber means all subs share the same airspace...this helps keep down the overall size of box and you can make it a lil smaller.. Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Basson50 Posted March 31, 2012 Author Report Posted March 31, 2012 (edited) Yea that's ren it gets down....back to the op subs up port back should sound best don't go too high with box do common chamber tune mid 30s you should get loud His subs were getting hot fast tho! Could only play them for a quick minute each but he said the two rear ones were brand spanking new. if you get 4 of anything with 10k+ rms youre gonna be loud l I only have 8 to 9 k though from the tiny bit of knowledge that I have. With 8 to 9k rms I'd get 4 night shade 12's because they sound fantastic. Heard them and also if you dont want to spend that much money go with the SA-15's they sound clean too. If you want some loud ass subs and want to upgrade your electrical and amperage and get some DC' You say 2 3500s strapped at 1ohm so that's .5 per amp..depending on box your rise is going to affect wattage..I wire at .35 each and rise to 10hm because my box is on the small side 16cf for 4 -18s...so let's say in a perfect world 7k on 12v..id do ascendant havocs you won't have enough power for mayhems unless you plan to upgrade...do 4 -15s and common chamber means all subs share the same airspace...this helps keep down the overall size of box and you can make it a lil smaller.. When I had talked to sundown they told me they have these special rings in there subs that can Cut down impedance rise a lot. Edited March 31, 2012 by Basson50 Quote
new guy Posted March 31, 2012 Report Posted March 31, 2012 if you plan on doing a 4 sub set up id diffidently do 15s not 12s no matter what. Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
Basson50 Posted March 31, 2012 Author Report Posted March 31, 2012 if you plan on doing a 4 sub set up id diffidently do 15s not 12s no matter what. Some 12"s are louder than 15"s , I heard four niteshade 12"s doin a 155db Quote
MrFree Posted April 1, 2012 Report Posted April 1, 2012 DUDE DD is the world record holder @182.7DB or something close to that... BUY 2 to 4 Z18's and more crescendo's... OR some DC's and tune low Quote R.I.P...99'Dodge Grand Caravan 03 Lancer Oz Big 3 HU-JVC KD-530 RCA's-rockerfosgate 41/2 inch Infinity mids Subs-(12's)2 Orion xtr124 Amp-Coustic600se battery-2 x stock, 1x Shuriken SK-BT20 Box-L-ported 3.562cubes@35Hz miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive) I dont have flex yet but damn I sound good,(coming soon....flex) Check out my HHR install Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/ Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
