i would bump that amp budget up a little.
here are some nice amps that do rated: AQ
you can of course get budget amps, like mb quart/hifonics. (still do rated.. but at 14.4 volts instead of a much more realistic 13.5, or 12.8 volts)
just keep in mind your electrical system.
stock electrical in a vehicle is generally good up to about 1k rms. (remember.. GENERALLY)
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
like a perfect match.
wire down to 1 ohm and you'd be set.
whats your electrical look like? probably need an upgraded batt or alt.
big 3 done?
Edited by Sheena
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
big 3 done?
Right now just factory alternator and slightly bigger battery than factory, id have to go check and the car isnt here right now. Its brand new but im limited to how Big of a battery i can fit in the car. Its hard to find a high power battery thats small.
I could always run a seperate battery else where in the car.
Edited by mgbadboyz
try XS power or Kinetik batteries.
stinger batts too.
all well known brands ran on this site
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
As far as mids, and highs for the front and back. I already have Polk audio DB series speakers throughout the whole car running off a 400x4 amp.
Do you have max dimensions? I only ask because my friend had a pretty hard time trying to fit 2 10's in an undersized box, even. Those holes in the back aren't too big if i'm thinking clearly.
The AQ220 and Zcon is a good combination.(be sure to set the gains correctly )
But if you go for a 2200W amp, you neeed some electrical upgrades, like a High Output alternator that puts out atleast 200-250amps and a extra battery.
  • Who's Online   0 Members, 0 Anonymous, 3006 Guests (See full list)
