KnockinthaStreetzof608 Posted March 31, 2012 Report Posted March 31, 2012 Well I currently have 2 runs 1pos nd 1neg of 1/0 shok comp wire ofc Well im going to buy ethier 4d3100's or 6xp3,000 batteries I currently have 2d3100s right now and a mechman 270 alt so for people that has ran more then 8,000watts in there build how many runs do you think will be good enough to keep my electrical up to par im thinking about maybe in total of 3 runs of power and 3 runs of negative to the back battery will be fine?? CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
Loslam Posted March 31, 2012 Report Posted March 31, 2012 You only supplied the number of batteries not what you are powering. But I'll say 4 runs of each neg and pos edit: If it's the AQs strapped in sig, probably more than that 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/
Watch the bass Posted March 31, 2012 Report Posted March 31, 2012 Do the math, how many amps your 8 K draw- Single OFC 0/1 gauge rund 300 amps, CCA wire 250 amps. I think with your idea. of 3 runs pos and neg you are on the safe side. "in the abundance of water, the fool is thirsty" Bob Marley
memphisBred Posted March 31, 2012 Report Posted March 31, 2012 Your alt can supply up to 270a and most OFC handles 300a. Id say your fine with what you have. I am using similar power and have 2 power runs and 1 ground run. Adding the power run gained me exactly .16 dB and kept my voltage about .2 higher on average. But more never hurts SMD Super Seller/Buyer Audison----Hertz----Rainbow
Emmet Posted March 31, 2012 Report Posted March 31, 2012 Do the math, how many amps your 8 K draw- Single OFC 0/1 gauge rund 300 amps, CCA wire 250 amps. I think with your idea. of 3 runs pos and neg you are on the safe side. 300 amps in theory.... voltage will drop before that. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
KnockinthaStreetzof608 Posted March 31, 2012 Author Report Posted March 31, 2012 Well ima be running 2 aq3500d1 strapped thinking 4 hdc4 12 dual 1 so ima run them at 2ohmstrapped daily and .25?? Iirc just for burps for what I remember when I had my XL strapped if I was driving I was at at 13.2voltage full tilt nd .7 strapped just thinking about future running more power im walling my stang I wanna get everything done so only have to worry about build instead of electrical CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
