losing two volts between front and back
the batts r 12.4 off 12.6 charging the stinger says 13.2 and its caibrated and i think hooked up right and ive never had a problem with the stinger until this car
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
7 Xs D3100s & 1 D6500
All Audio Techinx OFC 1/0
Doing 55s at 26hz!!!
And its a piece of junk. both your batts float low. 12.8 or up. Im willing to bet if you actually had a meter ( a real one) youd find the problem in no time.
like a fuse thats partially blwon but doesnt nlook it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I will try to word this the best I can here...
When you hook up the stinger volt meter to the amp,do you use a different length of wires to read that voltage than what you would use to read the battery. Like you use a 5 foot wire to read battery and then a 12 foot wire to read amp? Because if you use a different lengthed wire then you will have to calibrate indivisually each time otherwise the voltmeter will not be accurate.
Edited by JeepGuy
- 1995 Jeep Wrangler -
ALL UNDER MASS TRANSFORMATION!
I think its your volt meter or lack there of... Get a real volt meter then recheck!
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
ill change fuses and update yall toworrow
you could buy a digital multimetere and stop relying on the POS stinger and do some actual troubleshooting.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
ok went and bought a 60 buck multimeter and check all my termials and changed all fuses still all same but i ran a run back to the back bats off my alt and its up to 13.1 at amp so im gonna charge my batts all night and buy a ho alt and go from there
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
I'd take back the $60 dmm and get maybe a $10 one? Save a bit of cash and i'm sure it wouldn't be a big difference in readings.
Check the resistance at each fuse holder, check grounds, etc.
You have the rear batts neg connected to the one up front?
I agree, you don't need that much precision and accuracy for car audio voltage readings.
Cheaper DMM FTW!
However, I've always wanted a Fluke brand DMM just because all the Engineers use one :)
  • Who's Online   0 Members, 0 Anonymous, 1296 Guests (See full list)
