C-Fizzy Posted May 23, 2012 Report Posted May 23, 2012 Don't think it's the same guy, Probably just some troll. Who doesn't know how to troll. Lol. Like how he quoted me in his interests tho. Fail. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
csmith21 Posted June 9, 2013 Report Posted June 9, 2013 Sounds like your amp give up on your system I'd prob check in on some new rcas because all of them wear and also check your amp and make sure its ventalated some amps will fry before going into protect mode if their hot. )cS(21#(
Amart88 Posted June 9, 2013 Report Posted June 9, 2013 Sounds like your amp give up on your system I'd prob check in on some new rcas because all of them wear and also check your amp and make sure its ventalated some amps will fry before going into protect mode if their hot. You do realise this posts over a year old right? My 2005 s10 blazer build. 4 zcon 18's walled.
Skax Posted January 16, 2014 Report Posted January 16, 2014 That escalated quickly. 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Skax Posted January 16, 2014 Report Posted January 16, 2014 That escalated quickly. i know this is old but i saw the sigs just wanted to see the posts haha 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Aj11 Posted January 17, 2014 Report Posted January 17, 2014 have you pulled the subs from the box yet? and to me it sounds like a voltage drop problem. i worked with a kid who had the same thing going on. he asked me to look at for him. i got in it he turned it up and the higher the volume the lower the subs. in his case his gain was all the way up. not saying yours is, but I'd check your battery and your alt. check with system off then at full Tilt. if you're dropping below 11 volts with a 1000w amp you got problems! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
