Maybe your DSP (3sixty.2) just for kicks, try pulling a pair of rca's outta the dsp, and go str8 in to your amp , maybe your highs..(since youll hear those the most) no static on those 2 channels, focus on the DSP,... just a thought, if your entire system runs through your dsp, and static on every channel,...gets me thinking....also, you could try to turn the adjustment pots on the "front" channel way up and way down on you 3sixty, does it get worse and "better" with the turning?..keep me posted, mine goes in this weekend....cheers and gl bro....
when i ran the new RCAs it as straight to the amp.
also still doesnt explain static with no RCAs hookup
you win some, you lose some
Long shot but is there anything factory left
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
When I get home ill type something drawn out
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Hey I tried pulling out my RCA's and yeah it still has that same static noise.So I'm with you on trying stuff to get rid of it
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
You said its still there when you pull the rcas. From the amp or from the head unit or the 360? alot of 360s cause noise.
pull the rcas from the amps. All of them. Is the noise still there?
If so Id start unhooking speakers. One at at ime til the noise goes away. When you find hte one that makes the noise go away( if you do) start looking into it. Could be the speaker wire is touching it. could be that you have a screw that you mounted it with grounding out on the frame. A factory wire could be touching a speaker Could be you nicked the speaker line putting them in. lots of things. IF the noise is still there when you unhook all the speakers you can rule them out.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeah I think he has tried disconnecting all the rca's from the amp and was still getting the noise.Im going to try disconnecting the speakers tomorrow since its 8 at night already then try moving the ground.So Brett I will let you know if either of the two help any.
Vehicle
DNX9980HD
3 DC 9k's
8 Nendo PWX 8's
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
21 D1600's
2 D4800's
All SMD RCA's
Viper Alarm
do one at a time. Eihter do the ground or the speakers. dont make too many changes because then you dont know what worked and what didnt.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
