Running multiple runs of 0 guage to alternator or front battery then alternator???
Hello everyone,, when your running multiple runs of 0 guage , do you run your power line coming from the back straight to the alt or to the front battery then the alt.... Rite now I have the big three done, then I have my power wires from the battery bank in the back running directly to the alternator. My grounds from the battery bank are running to the motor mount in the front. I noticed that when I added two grounds in the back from my battery bank to a bolt under the seat my voltage went up a little. Are my connections rite or should I change something up.
It is usually easiest to use a battery as a common point for all connections since you have more options as far as terminals or connections. Technically speaking, running directly from the alt reduces connections that reduce flow (ie. more resistance which equals lower voltage and lower current) but a minimal amount if done correctly.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
you are going to have an easier time getting it to the battery. Its easier to buss bar at the battery htan the alts. Either way is fine and ive seen it done both ways.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Was thinking of disconnecting from the alt and running straight to the battery
you will still need an upgraded run from the alt. if your alt is capable of 270 amps you wont be sucking that thorugh the stock wire
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 1310 Guests (See full list)
