XS Power
I am planning on running a Skar 1500 at 1 ohm with all 0 gauge wire including the big 3. I have my stock alt and i don't know how many amps it puts out. It's going in an 03 ford Taurus. I would like to just run the one battery under the hood and I'm wondering what battery could handle all that.
Thank you.
Just get whatever one will fit in place of your stock battery. Should be all you need
cheap walmart battery should work... LOL. go for an XS power battery or a Kenetic. go to their sites. they have the dementions of the batteries on their sites so if you go out and measure your battery you can match them up that way.
Thanks guys. And I know enough to not get a Walmart battery. I want xs power from all the good stuff I've heard about them on this site. I was just looking for which line to look into so I wouldn't have much if any voltage drop using it daily. But not turned all the way up daily. And I'll go measure later today =]
That is a Group 36R battery. We do not have a direct replacement for that battery. A lot have put the D6500 in there, but you would want to check and make sure it will fit for you. The D6500 would be plenty of battery for that system and leave you room if you decide to go larger in the future.
