Vids,Updates,4 SKAR VVX 15's,Toolmaker Duals,Kids Hair Trick,Windshield Flex
It's ya boy ChillMasterWill 2 weeks ago I was "done" w/my 4Runner & my plan was just to go to SBN & have an awesome time(which I damn sure did) but being around the best in the world in the car audio industry & all of the awesome systems has me adding 2 MOAR SKAR VVX 15's true bass heads can't ever get enough LOL!
ride 1999 Toyota 4Runner
I've competed in DB Drag Bass Race 129.9 Class and Street C best score 146DB w/this setup 2 SKAR VVX 15's and going to 4 SKAR VVX 15's I hope to be close to 148-150DB and try competing in IASCA Bass Boxing
-KENWOOD Excelon KDC-X492 Head Unit.
-KNUKONCEPTZ RCA’s.
-RE Audio RE6.5FR Co-Axial 6 ½" Front Door Speakers
-RE Audio RE5FR Co-Axial 5 ¼" Rear Door Speakers.
-2 Sets RE Audio TW-1Tweeters Front door Factory Sail/Rear C-Pillar.
-AUDIO CONTROL EPIC 150(Volt Meter/DB Meter).
-18 Gauge Co-Axial/Tweeter Wire.
-8 Gauge Subwoofer Wire.
-HIFONICS XX-Colossus Mono Subwoofer Amplifier(3200 x 1 @ 2-Ohms)
-HIFONICS 4 Channel Mids/Highs Amplifier(110 x 4 @ 2-Ohms).
-KICKER Power/Ground Distribution Blocks.
-4 SKAR AUDIO VVX15D2 15” Subwoofers.
-XS POWER D3400 Battery.
-The Big Three Upgrade(1/0 Gauge-Alternator/Battery/Power, Battery/Engine/Chassis/Ground).
-KINETIK Battery HC1400 Top Posts, Side Post Adapters, Terminals.
-KICKER Hyper Flex 0 Gauge Power/Ground Wire.
-STINGER/KINETIK Battery Terminals.
-½” TECHFLEX Braided Expandable Sleeving(Blue/Gray).
-AUDIOPIPE 300 Amp ANL Fuse.
the new box will be built out of 3/4 MDF like my last box and will be screwed/glued together cut out by a skill saw and it will have 4 Precision Port 6" aero ports I bought from Parts Express(these things are huge)the box tuning will be 32 hz
9.8 cubes internal volume
ALL corners have 45's we used corner mold from Lowes
the back wall seen through the ports will be black(we added black paint the resin and I'll be adding a SKAR decal so when you look through the ports you can see it)
also from Parts Express I ordered the black bar grills to protect my subs(me and my two sons travel alot)
there will be a 1/2" galvanized pipe(stripper pole) to help my SKARS "perform" lol it will be secured w/carriage bolts top and bottom the top bolts will be exposed for show
the box will be painted w/grey flecstone paint
the amp will "float" on the back of the box"
the top will be two layers and the subs will be recessed
the ports are pressure fit in w/resin for a seal and will have fiberglas chop mat to help strengthen them
this box will be bolted to the frame just like my last box
we've taken our time on this box to get it done right(me and my brother from another mother Hugh E. Rection you're right bro we make a great team)
I bought 40 feet of 8 gauge power wire for the subs all wires cut equal length(I did this over two episodes of CSI Miami
Edited by ChillMasterWill
William - Metter,Ga. Dad, Self Installer/Fabricator & Repair Tech, Weightlifter, Motivator,
Team SKAR Audio Captain, Team Deadly Hertz Georgia Leader
99 Toyota 4Runner SR5, "Rolling Thunder"
Daily Driven, No Wall, C-Pillar Build, BASS LIFE!
2K16 SBN MECA Park and Pound DB3 Champion
2K16 SBN ISPLL Real SPL Class F Champion
Second Skin Damplifier Pro, Kenwood eXcelon KDC X498, Clarion EQ, Knukonceptz RCA's
The Big 3, Sky High Car Audio OFC & Kicker Hyperflex Silver Tinned 1/0 Gauge
Singer 340a Alt, Northstar NSB-AGM31, SMSAGM480, 12 NessCaps Super Caps
Rockford Fosgate 3Sixty Line Driver, The Oval Port Tuned To 31 Hz, CNC Machined
4 SKAR ZVXv2 D2 15's, 2 SKAR SK-4500.1's, 4 SKAR PAX 6.5's, 2 SKAR LP-80.4's
MEMBER OF THE YEAR 2013
If you don't have any haters, get some, best motivation there is...
Will, it's really turning out great so far! Keep it up man!!
yeah dude thanks, doin work!
Good job by going with the precision ports, they make a huge difference
Don't mean to be negative will but why 4 aeros???? I think its too many man
from our calculations it should do pretty good, we'll see.....
The 4 aeros are 6inches internal diameter each. That is 28in^2 of moving mass per port. The enclosure is 9.8ft^3 of internal volume after all displacements. This gives us a ratio of 11.4in^2 of moving mass per ft^3 of internal volume. This is a very ideal ratio for a daily driver system. It gives a great balance between port gain, and musicality. It will still get plenty loud, and the subs will also play further below port without unloading.
The majority of box builders will usually build at 14in^2 per cube as a minimum, then upwards of 18-20in^2 to get more output for the meter. Once you do the math, its actually not as much port area as it seems.
Edited by Hugh G. Rection
Owner of BigAss Ports
  • Who's Online   1 Member, 0 Anonymous, 639 Guests (See full list)
