Wiring Duals Alts?
Im sure this has been answered b4 but everytime i put it in the search nothin comes up.Im gonna order dual alts for my hoe one 240 and one 300.I wanted to know how I wire it?Im guessing I plug in the 240 to the stock wiring and then what :blink: ? find another plug for the 300 and splice into the stock wiring or just run the 300 to the battery when i do my big 3?Im tryin to understand all this so bare with me :blush: .Correct me if Im wrong but arent the Iraggi's internally regulated??If so I NEED to splice into the stock wiring,RIGHT? :blush::(
Please help guys
I NEED THIS KNOWLEDGE
Aloha
Smokeumtires
Most Iraggi alts have internal regulators, I think it's only an external regulator if you order it like that???? Correct me if I'm wrong.
SO splice into the stock wires with the 2nd alt ....and run two 300amp fuses between alt and batt when doin the big 3.One more question. when its all done since I spliced to the stock wires do i need to change the stock fuse?Or no leave it?
I'm with Smokeumtires on this. Any information or instructions on how to actually install and properly test a dual alternator system would be really helpful. Maybe if we could get some who's currently doing a multi-alternator install could share the experience. Maybe we could sticky the information just like the Big 3 thread above.
Right now the only really good hands on tutorial I could find on installing a dual alternator setup was this one from Car Audio and Electrioncs website. Its a step by step using Dave's D.C. Electric's dual alternator kit.
http://www.caraudiomag.com/technical/0206c...ator/index.html
2007 Chevy Suburban LT1
Pioneer AVH 5700 DVD
Diamond Audio D3 6 1/2 components
Kicker 06ZX650.4 amp
Kicker 06ZX2500.1 (x 2)
DC Sound Lab Level 4 18's with Level 5 coils
Autotek Mean Machine 400.1D (replaced)
Soon to come:
rims
body kit
flow master pipes
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
On my truck, I ran the power wires from each alt directly to the battery and I personally didn't use any fuses on that wire. My '06 Yukon alt has a 2pin plug. One is the voltage sensing wire and the other is the stator wire (turns on/off the alt). The factory alt is computer controlled which I wanted to bypass with my second. My second alt is a 200a large case GM w/ the 4pin plug. Only one of these wires is actually needed. It is known as the "L" wire (stator wire to turn on/off the alt) and in my case was the yellow one. This wire was connected to a 12v ignition source so the alt turns on/ff with the truck without any interference from the computer.
  • Who's Online   0 Members, 0 Anonymous, 4447 Guests (See full list)
