So how you might want to get it working is first plug it in to see if it works,
If it doesn't work check if the fuse works.
If it does, your input will have to be an RCA. Chose the speaker that you want to use, find out its ohms, then set the ohm selector to the proper ohm(age) then set the 901 or other to other since you wont be using the Bose 901s.... that should work. I would recommend starting the volume at minimum and work your way up.
it doesnt work but i did plug it in to see. fuse wouldnt come out tho. i really wanna get it going tho
I think that you need to get the fuse out somehow, or i cant be much help... Good luck for what it is worth
Im a broke student. still manage to have a pretty good system though.. (at least i think)
got it!! it works theres a hidden button on it. the 901's subs are blown. but the tweeters sound amazing still. i really need to get them fixed. but after getting it set up and running it sounds really good. i just pushed it to hard a few mins ago and it went into protect mode and overheated. but im running like 400-500watts off each side. it doesnt sound distorted at all with the bass all the way up. ill get pics of my redneck system if anyone wants it. 3 wires down into 1 =] per side
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
This is the most powerfull amp i have.
Vintage CLEAN power.
http://www.allegroso...nsui_B2101.html
260W at 8 ohms per channel (it's a 2channel.)
350W at 4 ohms per channel .
Both of those numbers with only 0.003% of THD.
These are some serious numbers.
You can go to 1% THD before the amps goes into protection mode, just before that point it makes about 320W at 8 ohms.
ANd yes you can bridge this beast.
All class A/B power.
Impressive amplifier you got there
Agreed, what do you use it for currently?
Nothing, it's just sitting there, i have better sounding amps, and all that power is too much in house.
Cool, hope it sounds good for years to come! that is A LOT of in house power. I would highly recommend getting the 901s fixed.
whoever had the old school BOSE...its a Spatial Control Reciever...here is a link to get the owners manual for it
http://worldwide.bose.com/productsupport/en_us/web/scr/page.html
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
ghetto system would be classified as putting your home subwoofer box into your trunk wired straight into the rear factory wiring...
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
Nah that's just stupid
Anyone know the rating on the bose? Like watt wise. I wanna find out and I'll use inverter in my car to run it ;)
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
100 watt per channel if you looked at the link stroupe posted.
So not the 400-500 watt you were expecting. ;)
100W per channel is quite a lot for a old-school amp.
^^ its not on there. and I don't wanna fill the stuff out to get a manual. But then tell me how it is 100w when I'm running 500w off each side and it hits harder and cleaner then my 200w each side stereo?...
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
