Walled 2006 Scion Xb Rockford Demo Vehicle 7000+ Watts!!
Well been working on a Scion Xb for awhile off and on with me and another friend . It's actaully coming along now so I figured its time for a build log and some pictures. Vehicle will be a Rockford Fosgate Demo vehicle when Complete.
SYSTEM DESIGN as of now:
Kenwood Double din undecided on model right now
6x Rockford Fosgate P3D4-12"s
Powered by 3x T1500.1bdcp's all birth sheets between 1920-1950 RMS!!!
Two sets of Rockford T1652-S Components up front
Powered by a T1000.4AD
Two set of Rear mounted Rockford 8" Marine Co-ax's M282B
Powered by a T800.4AD
Electrical- Shuriken BT-80 up front, 2x Shuriekn BT-120's out back, Ohio Gen Alternator, and PD9260C Power Supply
3x Rockford Fosgate RFC10HB Hybrid Power Capacitors
Also leaving room for additional high's to be mounted in the wall, and A-Pillars in the future. (Possibly new Rockford Pro Audio)
2007 Scion Tc- T1500.1bdcp & t600.4, Three P3D212's Ported at 40hz, T2 6.5" Components, Rockford Marine 8" coax's. Kinetik khc1400 in back, Kicker 0 gauge
1999 Cherokee- Rockford Prime Amps 300.4 & 500.1,Big 3, Rockford 6.5"Comp.s and 6.5" 2ways, 2 12" P2's Ported basic winter beater
2002 Mustang Convt.-T1500.1bd & 400.4, 3 P3D210's IB, JBL components all the way around,Rockford 4 gauge, Big 3, Kinetik khc800 in back
Under hood BT-80 all rockford fosgate ) gauge "Big 3" and positive and negative runs to the back.
Ohio Gen Alternator with ) Gauge power and Ground
"Big 3" Fusing
Rear Battieries Cut through the floor starting to wire them in......
Here's a crappy shot of the wall 6-12"s, double thick face, double thick outer port wall, port braced with all-thread, front rear corners 45'ed, center of face 2"x4" braced. I don't remember box tuning I'll have to look it up.
Rear of wall starting to fab a rack for the three RF Hybrid Cap's
Starting on the amp layout ;)
Another shot of back wall...
Wall with red suede on and amps mounted.
Cap Rack Suede'ed up and caps mounted
Charging Caps with rockford resistor board...
Why not get a RF Hu? Looks good so far though.
There are future plans for the headunit too, but the goal for now is to get it up and and playing for some summertime demos.
Building some homemade RCA distrubution blocks on the cheap. (Cheap but effective)
First plate for subwoofer channels basically 8-common RCA jacks.
Here the Sub RCA box mounted on the wall.
Now for the highs, you have four inputs on the box itself basically Y'ed off to two outputs.
Alll soldered up ready to go....
Both boxes mounted up.
Here's another shot you can see white and red rings for left and right.
