Ok here's a rough pic of my Nendo
It should look somewhat similar to your amp. The main things you want to focus on are subsonic, LPF, and gain. Other can chime in as I'm tired.
So that means you have everything turned down to the minimum. now to put it set at 30hz all you would do is adjust the gain and the subsonic but leave the lpf alone right???
I would adjust the subsonic. Now this can take trial and error as I don't know what your box is tuned to and you could hurt you subs if they play to low listen for bottoming out or if it starts to smell funny. Now with the gain I wouldn't go past 1/4-1/2 until you know you have a clean signal.
Edited by FeArZ
2009 Tahoe
2000bc Cresendo POWA Need 3500
2 Sundown Zv3 18 high rolled sexiness
dual alt bracket with Singer alt(coming soon)
Mtx Q(not sure if I'm going to use)
Knu wire and RCA's
Bass Head Bands
Oh and a few pairs of Jordan's
ok. you cant really "tune" a ported box with your amp. i mean you sorta can. ok so your box is tuned at a specific frequency. most likely it is a 45 hz + tuning. most prefab boxes are high tuned. most of the time you want to set your subsonic filter about 5 hz below tuning frequency to protect woofers. in your case, i would think that your port area on that box is too small and you may get enough pressure to save your woofers.
try this. set your subsonic at about 30 hz. and your LPF at about 80 hz and play a wider variety of music and make sure speker doesnt bottom out. ( you hear a click noise) or you here the woofer unloading where no tone is produced and speaker is flailing and moving air.
then set your gain accordingly trying not to clip.
you can adjust your subsonic and LPF to see what they do. the lower you set your subsonic filter, the more lowend you will bring out, but if you bring too much out you can wreck your woofers from unloading. find the sweetspot where you get most bass and lowend and speakers still protected.
Thanks that's what i was looking for all along, so in all essence when i have a box built i have to select the frequency i want to play it at mainly and i tweak it with that frequency being the base right???
im going to bed. if you want any questions answered you can pm me. ill answer it later today. peace
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
i dont quite understand your epiphany ahha. yes when building a ported box you must select a frequency to tune it at based on vechicle and on subs being used. then set subsonic filter and LPF to get desired frequency response while protecting speakers
BMW M340 xDrive
ok. you cant really "tune" a ported box with your amp. i mean you sorta can. ok so your box is tuned at a specific frequency. most likely it is a 45 hz + tuning. most prefab boxes are high tuned. most of the time you want to set your subsonic filter about 5 hz below tuning frequency to protect woofers. in your case, i would think that your port area on that box is too small and you may get enough pressure to save your woofers. try this. set your subsonic at about 30 hz. and your LPF at about 80 hz and play a wider variety of music and make sure speker doesnt bottom out. ( you hear a click noise) or you here the woofer unloading where no tone is produced and speaker is flailing and moving air. then set your gain accordingly trying not to clip. you can adjust your subsonic and LPF to see what they do. the lower you set your subsonic filter, the more lowend you will bring out, but if you bring too much out you can wreck your woofers from unloading. find the sweetspot where you get most bass and lowend and speakers still protected.
When you create your box, you will choose a freq.. some like 31, 32, 33, 34, 35, 36, 37, 38, 39, and most.. don't like 40. :) It's all preference. I am trying to learn the whole low pass ect but your SSF Subsonic filter is basicly to stop the freq from being sent.. so let's say your box is tuned to 33 hertz, you have your subsonic at 28, the amplifier won't send a signal under 28 hertz to protect your subwoofer.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
Ok i got it now it make a whole lot more sense no wonder why my lows are good but not the best. thanks you've been very helpful!!! but one more thing i'm not quite getting what does the subsonic do to the bass???
Kind of lost on what the question is. Most people get the box tuned to the type of music they listen to. Most rap I have is about 28-37hz so I have my box tuned to 33hz and my subsonic is 28hz. LPF is 80. Now I can play rock and stuff, but my box is not tuned for it.
Edited by FeArZ
2009 Tahoe
Knu wire and RCA's
Bass Head Bands
i saw this just before i got off. the filters are called filters for a reason. they dont just cut off all notes at the frequency you set to. they cut of db per octive. so it is a gradual slope cutoff. LPF is the cutoff on the high end. subsonic filter is cutoff on the lowend. they filter out frequencys above or below them. thats why it will be different in every system cause the amp filters will be different maybe, or loading in vechicle wil be different. thats why you must play with it and find settings you like best while keepign woofer safe. so LPF cuts off bass notes above frequency you set to. and subsonic filter cuts of frequencies below what is set to. but it does not cut off all frequencies to 0 it just makes the notes have less amplitude. the further they get away from the setting you have.
BMW M340 xDrive
oh ok now i get it thnks
i know it was a mistake but the whole time i had my bass boost at max, my subsonic at minimum and my frequency at maybe 80 so does the frequency work the same that number is where it picks up the bass untill the lowest you set your subsonic filter for???
  • Who's Online   0 Members, 0 Anonymous, 2809 Guests (See full list)
