2X dB Drag/MECA event 5-19-12 Fresno CA
lol mod 5 in meca is the high number class. unless you think youll be the loudest there mod 5 is a def second place trophy.
Ill just hold to that $50 lol.
Nowhere near those numbers.
lol
try park and pound
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
I'm going for a mid 36 or higher p&p did a 136.3 last show but it was a 1x...if toad an eric show up I'm not doing mod5 or ss3-4..mite play in 49.9 if you guys do early brackets
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
